Home > Puma (Tdci) > Can any EGR experts advise, please? |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Not much response to previous query. 2010MY 90, engine running fine since recent service. I get the 5 EGR cleaning cycles on shut down, But It also seems to do 1 cleaning cycle on overrun. If I start engine and run it up to 2000revs then take foot of gas pedal I get an EGR cleaning cycle "chukka " noise. If I disconnect EGR plug then no noise. Is this normal? LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
15th Apr 2012 2:04pm |
Off to try mine Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
15th Apr 2012 2:32pm |
Can't hear anything from inside the cab - do you have your head in the engine bay? Tell someone you love them today because life is short.
15th Apr 2012 2:37pm |
Thanks ZeDefender and MK. I was sat in cab. Didn't notice this happening prior to B service, a few weeks ago. Engine is running fine and Fuel consumption is unchanged. The only difference is this noise, which MUST be the EGR as it stops if I disconnect the EGR plug. LANDYWATCH
15th Apr 2012 3:44pm |
According to the Defender expert at the Dealership, this is normal. They offered a free health check including the EGR, so we will see. LANDYWATCH
16th Apr 2012 7:09pm |
I do wonder how you can hear it from the cab - either your engine is whisper-quiet (envy) or the EGR valve is sodding loud
I have to listen quite carefully to hear the self-clean cycle when I switch off... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
16th Apr 2012 7:49pm |
Not overly loud. Cannot hear with radio on volume 12 ( Land Rover unit ), but do tend to drive with window open. LANDYWATCH
16th Apr 2012 8:45pm |
16th Apr 2012 8:50pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Simple answer it's knackered mine did that you could here it at 2000 rpm tell em to change it
16th Apr 2012 8:51pm |
I agree Mick, it probably is, but everything is working well at the moment. But can you, or anyone, explain how or why the EGR valve carries out a cleaning cycle whilst the engine is running. LANDYWATCH
16th Apr 2012 9:14pm |
No idea but mine ran brilliant when the egr was knacked smooth more mpg got the new one fitted and it's not as smooth |
16th Apr 2012 9:31pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2623 |
It could be that the EGR valve is all gunked up and thus sticking when the revs drop. Chuck in a bottle of diesel cleaner and see if that clears it up? If not, regular doses of 2SO should do the trick -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
17th Apr 2012 8:59am |
Have used 2SO for past 21,000 miles at 250mls/tank. LANDYWATCH
17th Apr 2012 4:54pm |
