![]() | Home > Puma (Tdci) > Can any EGR experts advise, please? |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Not much response to previous query. 2010MY 90, engine running fine since recent service. I get the 5 EGR cleaning cycles on shut down, But It also seems to do 1 cleaning cycle on overrun. If I start engine and run it up to 2000revs then take foot of gas pedal I get an EGR cleaning cycle "chukka " noise. If I disconnect EGR plug then no noise. Is this normal?
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Off to try mine
![]() But shout it at them in German because life is also terrifying and confusing... |
Can't hear anything from inside the cab - do you have your head in the engine bay? Tell someone you love them today because life is short.
Thanks ZeDefender and MK. I was sat in cab. Didn't notice this happening prior to B service, a few weeks ago. Engine is running fine and Fuel consumption is unchanged. The only difference is this noise, which MUST be the EGR as it stops if I disconnect the EGR plug.
According to the Defender expert at the Dealership, this is normal. They offered a free health check including the EGR, so we will see.
I do wonder how you can hear it from the cab - either your engine is whisper-quiet (envy) or the EGR valve is sodding loud
![]() I have to listen quite carefully to hear the self-clean cycle when I switch off... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Not overly loud. Cannot hear with radio on volume 12 ( Land Rover unit ), but do tend to drive with window open.
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Simple answer it's knackered mine did that you could here it at 2000 rpm tell em to change it
I agree Mick, it probably is, but everything is working well at the moment. But can you, or anyone, explain how or why the EGR valve carries out a cleaning cycle whilst the engine is running.
No idea but mine ran brilliant when the egr was knacked smooth more mpg got the new one fitted and it's not as smooth |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
It could be that the EGR valve is all gunked up and thus sticking when the revs drop. Chuck in a bottle of diesel cleaner and see if that clears it up? If not, regular doses of 2SO should do the trick -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Have used 2SO for past 21,000 miles at 250mls/tank.
