Home > Puma (Tdci) > Clunk on acceleraton & decelleration.
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
My 2008 90 has developed a cluck on accelleration and decelleration. It's not too bad, but annoying. Much playing around today seems to suggest it's either the rear prop' (although no play can be felt) UJ bearings worn or the flange bolts loose (to be checked tomorrow).
I'm hoping it's one of the above because if it's the diff' or drive shafts it's gonna be painful in the wallet.
Anyway, in the mean time and whilst I'm underneath I might as well grease the uj's and check the oil level in the diff'. Anyone got any idea what grease I should use and which oil should I use in the diff'?
Many thanks.
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #139624 16th Apr 2012 8:04pm
MK
Any NGLI-2 grease. As for oil any GL-5 80W-90 or 75W-90.
Did you have the clutch exchanged any time? Puma 110" SW
Post #139628 16th Apr 2012 8:09pm
Romadog
A lithium based grease. This would only, if your lucky, hold off the inevitable for a short while. Did you test for play in ujs with park brake on or off ?
EP90 in the axle
Post #139631 16th Apr 2012 8:13pm
MK
Not all EP90 are suitable. It has to spec GL-5 Puma 110" SW
Post #139634 16th Apr 2012 8:15pm
jst
why the GL5 spec? is thats whats in the book? i thought that was hypoid diffs applications and such like. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #139641 16th Apr 2012 8:24pm
MK
That�s in the book. GL-5 has more sulphur as a Extra Prssure (EP) additive. GL-4 are medium pressure oils (gearbox, Tbox, etc) Puma 110" SW
Post #139650 16th Apr 2012 8:50pm
jst
ok, cheers Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #139655 16th Apr 2012 8:53pm
cinstone
Cheers. No, still on original clutch (43+k miles). The clunk also occurs over bumps as you drive, so my thoughts are loose bolts.
Post #139670 16th Apr 2012 9:27pm
cinstone
EP90 in the axle
Good question as to weather I had the parking brake on or not. Can't recall. My gut feeling was that it was on, but not sure now.
It was awkward to rock the vehicle to and fro from underneath and check this and that at the same time, but you could feel the clunk through the base of the diff' pan.
More checking tomorrow.
One would have hoped that the UJ's would have been greased at the last service about a month ago, but as they couldn't be bothered to refit the oil filler cap, perhaps I'm hoping for a bit much here Wink
Thanks so far.
Post #139674 16th Apr 2012 9:35pm
AndrewS
Splines are worn on the rear drive flanges Thumbs Up 130's have feeling's as well you know Smile
Post #139679 16th Apr 2012 10:15pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Long shot - check the prop bolts to the brake drum are tight. BM52
Post #139681 16th Apr 2012 10:25pm
bwanashamba
2011 Defender 130 Puma 2.4 HCPU Alpine White
check the rear A frame ball joint, i had similar clunking sound in my tdi, ball joint was worn, new ball joint sorted it out Very Happy
Post #139714 17th Apr 2012 6:36am
cinstone
Cheers for all that. More checking tomorrow as I've just got back from underneath him.
No sign of play in the prop', but two nuts at the transmission brake end tightened a tad. They were not lose by any means, but tightened a fraction.
I've sussed the original source of the cluck/taping noise, which got me looking in the first place. The front pad's are rattling Embarassed.
Thanks all.
Post #139844 17th Apr 2012 2:57pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Possibly 'A' frame ball joint.
Post #139856 17th Apr 2012 4:47pm
cinstone
Not the above "clunk", but found another knocking this afternoon. Front left mud flap was loose Rolling Eyes.
Post #139991 17th Apr 2012 11:18pm
