![]() | Home > Puma (Tdci) > Oil filter? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
Lie down flat on the ground-if you do not have a lift- with your head in about as far as the sump. The oil filter is encased in a black plastic container with two clips or lugs at the bottom. It is a small unit compared to other Defenders. I am surprised no one has told you to follow the leaks
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
12000 miles or first service they don`t change the fuel filter
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Nothing quite like having confidence in the guys you trust your defender to !!!!
![]() If you have to check up on them,, take it elsewhere ![]() Main Brian James Trailer Dealer for South West UK |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
Very little gets changed at the 1st and 2nd service (for my liking) Mike
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 668 ![]() ![]() ![]() |
Well the circus begins,
New clutch on monday and faulty steering damper explains the guess work on the steering front. At least its still under warranty. |
Ian
What were the problems you had with the steering, I can't find your post about it ? A friend of mine has a 110 (2008) which has very vague steering compared to mine (2009). My initial thought was the bushes but they look fine. I was wondering if his steering damper was also at fault. Bob |
Bob,
The steering damper was basically loose and needed tightening up. My steering was rubbish and i should have really checked it myself. The rattle in the gearbox resulted in the new clutch. Ian |
