Home > Puma (Tdci) > Oil filter? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4646 |
Lie down flat on the ground-if you do not have a lift- with your head in about as far as the sump. The oil filter is encased in a black plastic container with two clips or lugs at the bottom. It is a small unit compared to other Defenders. I am surprised no one has told you to follow the leaks 1982 88" 2.25 diesel
6th Aug 2009 3:34pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
12000 miles or first service they don`t change the fuel filter
6th Aug 2009 8:03pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Nothing quite like having confidence in the guys you trust your defender to !!!!
If you have to check up on them,, take it elsewhere California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
6th Aug 2009 10:22pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Very little gets changed at the 1st and 2nd service (for my liking) Mike
7th Aug 2009 9:23am |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 668 |
Well the circus begins,
New clutch on monday and faulty steering damper explains the guess work on the steering front. At least its still under warranty. |
7th Aug 2009 2:52pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Ian
What were the problems you had with the steering, I can't find your post about it ? A friend of mine has a 110 (2008) which has very vague steering compared to mine (2009). My initial thought was the bushes but they look fine. I was wondering if his steering damper was also at fault. Bob |
7th Aug 2009 3:58pm |
Bob,
The steering damper was basically loose and needed tightening up. My steering was rubbish and i should have really checked it myself. The rattle in the gearbox resulted in the new clutch. Ian |
8th Aug 2009 5:50am |
