Home > Puma (Tdci) > Oil filter?
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Oil filter?
Guys,
Mine goes in for a 12000 mile service tomorrow and i'm going to mark up the bits they should change just to check up on them.
I've found the fuel filter but after searching high and low (and getting a fair amount of salisbury plain in my eyes) i can't find the Censored oil filter.
Any ideas? Embarassed
Ian
Post #13896 6th Aug 2009 1:31pm
spudfan
Ireland
Lie down flat on the ground-if you do not have a lift- with your head in about as far as the sump. The oil filter is encased in a black plastic container with two clips or lugs at the bottom. It is a small unit compared to other Defenders. I am surprised no one has told you to follow the leaks Rolling Eyes 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #13900 6th Aug 2009 3:34pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
12000 miles or first service they don`t change the fuel filter Thumbs Up
Post #13908 6th Aug 2009 8:03pm
TJ101
Nothing quite like having confidence in the guys you trust your defender to !!!! Shocked
If you have to check up on them,, take it elsewhere Evil or Very Mad California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #13911 6th Aug 2009 10:22pm
mse
Very little gets changed at the 1st and 2nd service (for my liking) Mike
Post #13922 7th Aug 2009 9:23am
Higgers
Well the circus begins,
New clutch on monday and faulty steering damper explains the guess work on the steering front.
At least its still under warranty.
Post #13943 7th Aug 2009 2:52pm
bob neville
Ian
What were the problems you had with the steering, I can't find your post about it ?
A friend of mine has a 110 (2008) which has very vague steering compared to mine (2009). My initial thought was the bushes but they look fine. I was wondering if his steering damper was also at fault.
Bob
Post #13946 7th Aug 2009 3:58pm
Higgers
Bob,
The steering damper was basically loose and needed tightening up.
My steering was rubbish and i should have really checked it myself.
The rattle in the gearbox resulted in the new clutch.
Ian
Post #13975 8th Aug 2009 5:50am
