![]() | Home > Puma (Tdci) > Heat safe mode |
If mine gets too hot it does this and caugth me out a month ago or so. I now monitor the temp and have an alarm to let me know when it goes over 100. ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
I dont understand how it does it though as I have towed a heavy off road caravan in temps above 40deg C with head winds for hours and have never had this problem.
I also have a UG and temp has not been over around 96degs yet. Could it be related to driving style? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2663 ![]() ![]() ![]() |
Bruce, another chap in KZN who resides in a hilly area has had that issue for 2-3 years. LR tried numerous things but eventually he took the plunge and fitted a bigger intercooler and reported that the problem went away. The ECU will cut power if it sees the temp climbing to prevent damage. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
thanks Naks. but why does it effect some Puma's and not others?
I know, right? I'm not sure about this, maybe it's something to do with the intercooler, some may be defective without LR realising it? The owner who did this wrote a thread about it somewher. He monitored the inlet and outlet air temperature at the intercooler, realised that was the issue and then got a bigger one. Something that LR did not even think about in the 2-3 years he took it back to stealer over and over. I'm also thinking of putting a bigger intercooler in as soon as the warranty is over, along with doing a decat. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
thanks Naks.
Sounds interesting what you are planning. Let me know the progress please. ![]() |
Will do ![]() Bruce, as a first diagnosis, ask your mate to check the turbo hose, as per this thread: http://www.defender2.net/forum/topic12314.html -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Now that does sound interesting, I wonder if that is why some folk get really good mpg and other don't?
Dare not ask how much a new bigger intercooler is? Does the colder air going into the engine via induction really make that much difference to the engine temp???? Boy |
Thanks Naks. You may have seen it....its Winston on LROC...
The Boy: It makes a huge difference to performance and engine temp. |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 ![]() ![]() ![]() |
It's not just that colder air in = colder air out, but also colder air = more dense air = more efficient combustion, so the engine has to work less hard for a given power output.
Around £450-£500... AlliSport or Alive...maybe slightly better with Forum discount ![]() ![]() |
[quote="MartinK"]
The Allisport one: Designed to replace the original much smaller intercooler on the Land Rover Defender TD4 / TDCi / Puma 2.4 fitted with Air Conditioning. This intercooler is over twice the size of the original Land Rover item! This highly efficient product is designed and manufactured by AlliSport Ltd and comes ready to fit utilising the original pipe work and mounting brackets. Constructed using our ultra efficient vacuum brazed core design with internal "turbulators" to increase cooling capacity. CNC stamp cut for quality and consistency and fully TIG welded by hand all in house. The increased cooling capacity together with the appropriate electronic tuning can allow performance to be increased to over 170BHP with an improvement in fuel economy. Fuel economy increaces by, on average 10% with a reduction in cylinder head thermal stress. Thermal stress is actually reduced as the EGT or combustion temperature is reduced dramatically. In order to get the best from this upgrade the fuelling needs optimising to suit. We offer remapping/rechipping facilities depending on vehicle model year. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Very nice but I am sure we could get it made up locally for allot cheaper. I know a few guys who make them for race cars Naks so perhaps when you are ready?
Indeed, local is always better ![]() Btw, I found the post/thread from that chap in KZN: http://landyonline.co.za/landyforum/viewtopic.php?f=5&t=3242 -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
