Home > Maintenance & Modifications > Cargo tracking from MUD advice
Brocade
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Java Black
Folks,
Any advice on where to install MUDs cargo tracking rails inside a Puma 110 XS SW ? I've removed the seats in the boot. Can they be installed along the upright section of the wheel arches over the felt lining ? Could one install the recessed version of those tracks by cutting into the felt lining ?
Thanks in advance
Post #138448 11th Apr 2012 11:52am
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
You can mount the surface mounted items anywhere within reason. If you are looking to hold things to the floor I would probably put them on the floor close to each side.
The carpet won't be deep enough to mount the recessed version, you woukld need to cut the wheel box too. The surface mount will mount over carpet without any major drama's. 2002 Defender 110 DC
Post #138458 11th Apr 2012 3:12pm
Brocade
Many thanks. Out of curiosity, how does one screw the nuts onto the bolts ? Does the floorboard easily lift up or do I have to crawl underneath ?
Post #138476 11th Apr 2012 5:27pm
ben_j85jty
Either use rivnuts which may require a special tool to fit, or crawl underneath and have a helper hold the the other end.
Enjoy! 2002 Defender 110 DC
Post #138498 11th Apr 2012 6:43pm
leeds
Use either a rivnut or alternatively get an allen key jammed against wheel arch and then crawl underneath.
Cargo tracking is good Thumbs Up
IF you know EXACTLY where you want your load rings consider these
£14 for the two short pieces of track, backing plates etc and two load rings
Brendan
Post #138516 11th Apr 2012 7:12pm
Brocade
Aha I have just learned something new...the Rivnut !
Many thanks for all the advice
Post #138547 11th Apr 2012 8:06pm
I would also consider putting something under the floor to spread the load depending on what you are tying down ?
Post #138557 11th Apr 2012 8:27pm
