Home > My Defender > Mine now - 2003 TD5 90 HT
Page 8 of 24 <123 ... 789 ... 222324>
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Looking good, makes me want another 300tdi to fettle and work on. I really enjoy the diy,
Will waxoyl in due course or paint the chassis?
It looks really good Thumbs Up Thumbs Up BM52
Post #137283 5th Apr 2012 8:28pm
RRUK
Going to paint the chassis and axles and then waxoyl inside and out, got all the stuff to do it, was the first stuff I bought in fact but you need decent weather and temperature. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #137396 6th Apr 2012 8:33am
RRUK
So, started on the La Salle headlining, jeez, why does everything have to take so long and why does 1 job create 5 more? Big Cry
Laid it out on the floor to see how the 3 pieces interlink, so I know which goes first etc, at least in 3 pieces its a little easier to manoeuvre than the larger sections for the 110 would be.
The front section needs some work, firstly the sun visors from my old headlining needed bolting on, which was simple. Next, the front interior light needs fitting and the La Salle headlining has no cut-outs yet, so it's into the workshop to create a template in cardboard before cutting the GRP. It requires a rectangular section cutting out to allow the light unit to sink up into the headlining space, otherwise the threads in the back mounting plate don't reach through enough. Measure twice, cut once. I used my new air compressor and sabre saw for the this and it made things so easy. Trial fit - all ok. Smile
In the rear I have 4 speaker mounting plates from La Salle (as I didn't want the headlining with speaker pods and a radio mount in the roof). All my wiring is in place in the roof of the LR ready to feed through for the 4 speakers, I bought 4 x 4"Alpines to match the new Alpine head unit. The speaker mounting plates need cut-outs for the speakers and a hole in the headlining behind for the speaker wires. The sabre saw worked again here but I hit a snag, the speakers are just a little too deep and foul on the headlining, so, I need some spacers. MUD seem to have some that look the part so will need to get a couple of pairs to lift the speakers out a few mm.
By the end of today, I'd cut all the speaker mounts but can't get any further, still need another pair of hands for holding it in place while I mark and drill and screw it in, section by section.
I then blacked up all the plastics and rubber work on the LR after the polishing yesterday, it really makes a difference to highlight all the window rubbers, wiper arms, door seals, tyres, arches, mudflaps, grille and light surrounds. Had to pop out in it to fuel up for Sunday, got lots of admiring glances and some waves from Landy owners. Thumbs Up
 2016 D4 HSE
Post #137453 6th Apr 2012 3:13pm
RRUK
Fitted RDX snow guard vents - prefer the sideways facing vents to the front ones.
Also fitted clear indicators all round.
Clear tail lights next, just need to get the bulbs. Need to ask about straight LED swap versions from Hong Kong on the Bay and if they are any good
 2016 D4 HSE
Post #138456 11th Apr 2012 2:36pm
RRUK
AT LAST!
The La Salle headlining has started to go in. What with being away on holiday or away for work my time has been somewhat limited, the Mrs Wife helped me hold it up while I drilled the holes and put in self tappers, then I wired up the speakers and mounted them, and then finally inserted the proper trim rivets in place of the self tappers one by one.
Hopefully will get the front section done tomorrow and then its complete!
You might just be able to see the recently fitted MUD Curry Hooks too. Splendid.
 2016 D4 HSE
Post #143615 6th May 2012 4:28pm
RRUK
I'm not sure why I post these things, no one ever makes any comments! Rolling with laughter
Anyway, the front headlining is now in, the La Salle version looks stunning in situ, and although a bit of a Censored at the front corners, it went in pretty smoothly, but it's certainly a 2 person job.
Here's the pics of the finished article for anyone that cares. Big Cry
 2016 D4 HSE
Post #143775 7th May 2012 11:25am
bob neville
Looks excellent Thumbs Up
I have got to replace the headling in my 90, either Le Salle or new take off's - fancy coming to Somerset to do mine ? Laughing
2013 Defender 90 CSW - sold
Post #143776 7th May 2012 11:33am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
What's lovely neat job, just what I need in my 90 as the headlining is sagging due to water ingress!
It would be an ideal opportunity to remove all the old stuff, seal the leaks and then soundproof and fit like new. Trouble is after having it like it for six years I'm beginning to like it the was it is, should have done it when I got it, but too busy driving about and grinning.
Looks like you are going to end up with a perfect looking truck by the time you have finished.
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #143778 7th May 2012 11:37am
jerseyman
Please keep posting, just because no one is commenting does not mean that no one is looking.
Great job on the headlining.
Brian
Post #143779 7th May 2012 11:39am
Green Machine
Looking really good RRUK. Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #143781 7th May 2012 12:17pm
Manx Ste
Isle Of Man 1996 Defender 110 Other HT Cairns Blue
Absolutely brilliant job RRUK!!!
You really have done a great thread showing people how to/what to do, and the photography is great as well. I'd like to thank you for documenting your hard work so the likes of lazy gits like me can follow in your footsteps - you've given me some great ideas and shown me what i want to do with my 110.
Keep up the good work and keep posting!
Cheers,
Ste. 96 2.5 N/A LWB 110 Hardtop
Post #143828 7th May 2012 5:04pm
RRUK
Wow, some great feedback, thanks chaps. Thumbs Up
I'm no mechanic, but I'll have a go at stuff. I've really enjoyed (most) of it!
I'd love to swap out the transfer gears for Discovery rated ones but I might just be punching above my weight with stuff like that, who knows. 2016 D4 HSE
Post #143968 8th May 2012 4:25pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Excellent stuff Thumbs Up
I really enjoyed reading all this.
So a big thanks for sharing your experiences Mr. Green
This 90 is really a beauty now Wink Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #143976 8th May 2012 5:22pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Thanks RRUK for your ongoing project report Cool 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #143982 8th May 2012 6:16pm
RRUK
A small update, thanks to the first spring evening which is dry! Enables some little jobs to be done.
Tonight I removed the rear rubber mat. The previous owner had fitted the cargo rings in the rear floor, but over the top, quite handy, but instead of trying to unbolt these I simply cut around them and removed the matting (quite heavy).
Once it was out I scrubbed and pressure washed it.
Next, I vacuumed, brushed, scraped, washed, mopped and scrubbed the rear tub floor out, very satisfying to get right into all the corners where dirt accumulates.
Once dry I used up my remaining aluminium foil backed sound deadening material on the wheel boxes, plus some of the aluminium tape over the joints as it makes it looks so much neater.
Both sides are now done and I will also do the main floor section, should improve the noise reduction. Will have to get round to that when I back from my week in Vegas on business. Whistle Oh, and maybe when I am back I will get me one of those all in one powered subwoofers for the stereo and mount behind the passenger seat. Nifty. Cool 2016 D4 HSE
Post #144012 8th May 2012 8:11pm
