Home > Puma (Tdci) > Puma 2.2 Turbo Hose |
With my manifold screaming like a banshee, what chance does a 2.2 have? Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
2nd Apr 2012 8:57pm |
Axel Member Since: 22 Jun 2011 Location: Bochum Posts: 107 |
I would appreciate it very much if you could keep us posted!!! THANKS!!!! Best Regards, Axel |
2nd Apr 2012 9:26pm |
Might be a good idea to fit a wider jubilee on 2.4s as well
First thing I'll look at when I'm "zuhause" again in München Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
2nd Apr 2012 9:34pm |
affiliate13 Member Since: 29 Jan 2012 Location: Belfast Posts: 82 |
Would fitting Silicone hoses void the warranty if it solved this issue?
2nd Apr 2012 9:54pm |
Allan Member Since: 09 Sep 2009 Location: Perth Posts: 166 |
I think half the problem is the hose clip design. It folds under the hose to hold the clip in place, this puts the host very slightly out of round. Perhaps try cutting the folded section from the clip or get some h.d hose clips
Allan |
2nd Apr 2012 11:42pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
I've always thought jubilee clips are such a poor design, they are a pain in the ass, surprised something better hasn't been devised yet!
3rd Apr 2012 7:23am |
There is a much better design clip available which I used to use on my Subaru's intercooler. Far stronger, and able to cope with big boost. Since modifieing the original clamp I've had no further problems. I have heard of a few 2.4's having hoses blow off over here.
Allan |
3rd Apr 2012 8:17am |
More info please? I expect when the dealers (try to) fix my turbo squeal they will b*gger up the hose/clip - I want to be prepared... Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
3rd Apr 2012 8:33am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4731 |
It is in such an awkward place too! Is it possible to remove the trunking from the air filter box to get at ithe clip without upsetting any of the sensors and then getting fault codes.?
Had a jubilee clip on a 200 tdi go. It was on the engine and led to copious amounts of oil being spewed everywhere. Happened to someone on the Australian site (the 200 tdi hose clip) too. I always carry spare hoseclips with me. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
3rd Apr 2012 10:00am |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 719 |
Simon, thanks for the heads up re this. I double checked mine this morning and all appears ok. but as the guys said, may blow under strain, so thats when mrs N goes to Tesco Saturday then In terms of an alternative product, i have used these on a previous car. much stronger and as long as you can get access you can tighten with much more purpose.
www.thor-racing.co.uk/files/mikalor_supra.pdf |
3rd Apr 2012 1:43pm |
Doublecabdefender Member Since: 17 Jan 2008 Location: Norwich, Norfolk Posts: 61 |
Hi Nidge
Wow that looks just the job, jubilee clips are so pathetic - I shall try and source one straightaway. I can see no problem getting it around the pipe whatsoever. Thanks for the info. Regards Simon 2012 Defender 110 DCPU XS 2.2 Puma Orkney Grey ''I can resist everything except temptation. '' |
3rd Apr 2012 1:58pm |
Mines similar! It won't pull off or wiggle about, will keep an eye on it though as they probably slide off gradually... The hose itself doesn't seem to have the right angle on it I bet everyone else's is the same because of this? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
3rd Apr 2012 2:27pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
chatting to the mechanics at the dealers today this hose has blown of on most of the 2.2s they have had and they are now checking them before pick up, they also said LR have not issued a fix yet, they also said the problem does not appear to happen on 2.4s even those that are older and work hard for a living DEFENDER 90 TDCI XS,
3rd Apr 2012 7:11pm |
if a 2.2 can produce as much power and torque as a 2.4 it must be more highly tuned/stressed .. blood, stone etc...
3rd Apr 2012 7:20pm |
