![]() | Home > Td5 > Is it possible to have an oil leak free TD5 ? |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
apart from leaky injector seals which are now sorted mine is pretty much leak free
Mine's as dry as a dry thing!
So's mine
![]() Now, where's that bit of wood? ![]() ![]() |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
Mine, very slight weeps, nothing really - there are more pressing things in life for me to worry about 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy ![]() |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 587 ![]() ![]() ![]() |
new in 05 36k when we sold it no leaks 2.4 90 XS
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
I'm sure I have checked the breather - I will double check. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I had a TD5 Discovery. Owned from new for 187,000 miles in 9 years. Mostly road-use with some greenlanes (and a lot of travelling in heavy snow).
I only had 4 leaks. 2 x transfer box output shaft (can't remember whether front or back, I think they both failed once each). 1 x driver's side diff housing (rear) 1 x rear diff input seal Other than that it was dry (well, dry enough not to spot the drive) throughout... In all instances my Indie sorted them for a reasonable price when the vehicle was serviced... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
Nobody posted the cliche about dry Landies yet
I hope its not too much to ask for 'a non oil leaking landy' nevermind the leak from the Alpine windows, which likes to drip on my knee, the leaking rear sliding windows. 1999 Defender TD5 110
changill Member Since: 13 Dec 2008 Location: North West - Preston/Lancaster Posts: 27 ![]() ![]() ![]() |
Had the following leaks:
Tx Box Rear Output seal Rear Diff Input seal.....twice Engine front Camshaft seal Clutch Master Cylinder waiting for a leaky FPR.....and hoping not to get leaky injectors or a leaky head gasket ![]() Nanocom Available in the North West |
I've had the leaky FPR and leaky cylinder - replaced with a new AMC one. Not a cheap job!
Front cam seal has been done twice 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1116 ![]() ![]() |
Have you actually checked the oil level...
![]() 1966 S2a 109 aka Betsy |
I have and it does need a little bit of extra oil. I check the fluids once a week 1999 Defender TD5 110
