![]() | Home > Technical > Window seals |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Niglyn,
In mine, as far as I remember, the rubber seal appears to be well placed. Anyway I will re-check during the weekend. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
The water will run out of the drain holes in the door,it doesn't have to be a tight fit. 2.4 90 XS
niglyn Member Since: 12 Jun 2009 Location: Surrey Posts: 82 ![]() ![]() ![]() |
Tight fit? There is a huge gap along the whole length. With the inner door frame made of steel and the outer aluminium door skin, electrolitic action will occur and the ally skin will corrode and end up full of holes. I know this as it happened on my 300tdi. this was after 10 years but it did have far better door seals. I replaced the doors on my 2a and again they bubbled through after a few years. Poor aftermarket panels which were bare steel on the inside, where one cannot paint.
Every other car in the world apart from the new pumas have seals that are a tight fit. I suspect LR have changed supplier of the seal, which to me, appears that the lower skirt is now too short so will never touch the door, let alone bell out to form a seal. I know the 300s had a good seal other than a rivit which lifts it slightly, I remember putting pug around it. similarly, my 07 was ok, I added a bit of extra pug at either end to stop water ingress. Having the 300 rot out, it is one thing I am vary wary of, thus am horrified with what I find on the new 09. |
niglyn, the doors on a puma are steel not ally. 2.4 90 XS
niglyn take a photo and show us what you mean
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
The skins? I know the frames have always been but the skin is usually alli Mike |
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 ![]() ![]() |
I thought the skins were alloy too. Get the magnet out time
![]() Richard 1963 Series 2A truck cab 2008 110 SW |
Richard was that all four doors checked
![]() 1968 1/32 scale Britains 109 Pick up. |
Ooops. A bit giddy with the trigger finger there. Interesting about the doors though. Richard 1963 Series 2A truck cab 2008 110 SW |
Steel! Yikes!!! Don't Ford know how good british car manufacturers are at making steel rust? I give these new puma steel doors 3 years till they start rusting out. I think I will drill a few holes in the inner frame (after removing the door panels) so Rustmaster will be able to get right in there and give it a real good squirt.
The poor fitting rubber seals are really going to let all the water into the doors. The seals do not have a long enough skirt on them to give a good seal, or on my vehicle, even touch the paintwork. Either LR have changed the seal they use or they fabricate the doors differently so the upstand where the seal clips into is too high. |
the only good thing is you don't have different metals to react with each other,just make sure the drain holes don't get blocked
