Home > Technical > Window seals
Page 1 of 3 123>
niglyn
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Window seals
Hi all,
Put my new defender in for warranty work. The horizontal rubber seal between the wind up window and the door has a big gap underneath, which will allow water to run down the window onto the rubber seal, under it and into the door frame, thus causing corrosion issues in later life.
LR refused to do the work saying they were all like that!
I have removed the seal myself to get a better look. The ally door skin bends at right angles under the rubber and then stops. The upsatand bit which the rubber seal attaches to is a seperate fabrication and where the two join is not water tight, thus all the water can seep through the joint. Also when braking/accelerating, the water will run along to the front/back where it can then easily run into the door.
On my 07 & 300tdi, there was no gap at all.
Would be interested to hear how other peeps landies compare.
LR also refused to attend to the rust on the chassis or bumper, saying it was normal for a brand new vehicle to be rusty!
Post #13375 24th Jul 2009 7:32pm
Eduardo
Niglyn,
In mine, as far as I remember, the rubber seal appears to be well placed. Anyway I will re-check during the weekend.
Cheers Eduardo
Post #13376 24th Jul 2009 8:21pm
Grockle
The water will run out of the drain holes in the door,it doesn't have to be a tight fit. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #13378 25th Jul 2009 9:01am
niglyn
Tight fit? There is a huge gap along the whole length. With the inner door frame made of steel and the outer aluminium door skin, electrolitic action will occur and the ally skin will corrode and end up full of holes. I know this as it happened on my 300tdi. this was after 10 years but it did have far better door seals. I replaced the doors on my 2a and again they bubbled through after a few years. Poor aftermarket panels which were bare steel on the inside, where one cannot paint.
Every other car in the world apart from the new pumas have seals that are a tight fit. I suspect LR have changed supplier of the seal, which to me, appears that the lower skirt is now too short so will never touch the door, let alone bell out to form a seal. I know the 300s had a good seal other than a rivit which lifts it slightly, I remember putting pug around it. similarly, my 07 was ok, I added a bit of extra pug at either end to stop water ingress. Having the 300 rot out, it is one thing I am vary wary of, thus am horrified with what I find on the new 09.
Post #13382 25th Jul 2009 10:15am
Grockle
niglyn, the doors on a puma are steel not ally. 2.4 90 XS
Post #13384 25th Jul 2009 10:20am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
niglyn take a photo and show us what you mean Thumbs Up
Post #13392 25th Jul 2009 3:39pm
mse
The skins? I know the frames have always been but the skin is usually alli Mike
Post #13405 25th Jul 2009 9:59pm
YORKSHIRELAD
I thought the skins were alloy too. Get the magnet out time Razz .
Richard 1963 Series 2A truck cab
2008 110 SW
Post #13406 25th Jul 2009 10:46pm
YORKSHIRELAD
2008 110 SW
Post #13407 25th Jul 2009 10:46pm
YORKSHIRELAD
2008 110 SW
Post #13408 25th Jul 2009 10:47pm
YORKSHIRELAD
2008 110 SW
Post #13409 25th Jul 2009 10:47pm
Grockle
Richard was that all four doors checked Whistle ,dealer told me that when the puma models came out Ford's cost cutters wanted steel used not ally on the doors. 2.4 90 XS
Post #13419 26th Jul 2009 10:53am
YORKSHIRELAD
Ooops. A bit giddy with the trigger finger there. Interesting about the doors though.
2008 110 SW
Post #13428 26th Jul 2009 3:30pm
niglyn
Steel! Yikes!!! Don't Ford know how good british car manufacturers are at making steel rust? I give these new puma steel doors 3 years till they start rusting out. I think I will drill a few holes in the inner frame (after removing the door panels) so Rustmaster will be able to get right in there and give it a real good squirt.
The poor fitting rubber seals are really going to let all the water into the doors. The seals do not have a long enough skirt on them to give a good seal, or on my vehicle, even touch the paintwork. Either LR have changed the seal they use or they fabricate the doors differently so the upstand where the seal clips into is too high.
Post #13481 27th Jul 2009 5:22pm
Grockle
the only good thing is you don't have different metals to react with each other,just make sure the drain holes don't get blocked Thumbs Up . 2.4 90 XS
Post #13482 27th Jul 2009 5:35pm
Page 1 of 3 123>
