Home > Puma (Tdci) > How long has your Gearbox and Transfer box lasted! |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
As we now know, my gearbox/transfer box have now lasted 20,000 miles, it is the bit that joins them that gave up after 20K.
Clutch, about one every 6K so far 70% road use, 30% off road, some very heavy. No towing. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
20th Mar 2012 7:25pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
24k miles. No problems with gearbox/transfer box or clutch. 90% on road hi-speed if possible don't like to be last in queue, 10% gentle off-road. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
20th Mar 2012 8:12pm |
AdrianCR Member Since: 23 Aug 2009 Location: Costa Rica Posts: 52 |
2008MY 65k miles one cluth, genuine Tbox,gearbox 90%very heavy off road.
20th Mar 2012 8:22pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
58K miles all original except for the oil, no problems,
had a word with opie about gear box oil when I was doing the transfer box oil as Tbox is every 48K but Gbox is 120K say land rover, opie recommend gear box oil every 40K? food for thought Mark |
20th Mar 2012 8:49pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
241,000 miles , no problems here, and yes I always pull away in second unless uphill or towing .
20th Mar 2012 8:53pm |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 |
43k+ miles. All original.
Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
20th Mar 2012 9:51pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
Zag just change your gearbox oil - you know you want to ! (just think of all that swarf - its in there grinding down yer splines )
20th Mar 2012 11:09pm |
Just under 40.000 miles, all on-road, infrequent long highway trips at 80mph, but main use is half city, half intercity. Gentle with the mechanics, but all original, gear- and transfer box, original clutch (has had the occasional light rattle at idle for a while, but that seems to have disappeared now. In two weeks time plan to change for the first time both gear- and transfer box oils (engine oil/filter every 4000miles), and also will change for the first time the diffs oils. Sofar all works a treat, touch wood will stay like that You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
21st Mar 2012 5:19am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2637 |
Gearbox: 2yrs, 29,000km, no tough offroad use
T-box: original -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
21st Mar 2012 11:56am |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 |
Mine is only 8k and nothing but smooth. A friends '08 TD4 has come from Africa recently and that machine runs now at 125k with first gear/transfer boxes. Never forget: cars have owner, Landrover have field service personnel.
21st Mar 2012 1:08pm |
coming up 24 months old, just over 10k miles and no problems. going in this week to have transfer box, gear box and axle oils changed.. will be watching the output
95% on road, did some off road in France and Switzerland no problems at all |
21st Mar 2012 8:36pm |
Utility110 Member Since: 21 Mar 2012 Location: Hants Posts: 8 |
New transfer box at 4k although I'm not sure it was right from new. Took it in to LR with a nasty clattering after long distance and then coasting to junctions. Service manager assumed it was loose clutch plate fixings but then called me back later kept the car for a few days.
minimal off road before, lots since with no problems. |
21st Mar 2012 9:58pm |
mudrut Member Since: 29 Feb 2012 Location: Stourport-on-Severn Posts: 80 |
I wonder if it would be helpful to put the model (90/110 and body type) and even tyre size/type, so we could see if the relative weight of the vehicle or loading on the transmission affects owner's experience?
Anyway, my vital statistics: 2008 110 Utility 54,000 miles often heavily loaded. Daily driving, long road trips, off road use - all original 2009 110 Double Cab 24,000 miles use as above. Both vehicles are usually shod with 285/75R16 BFG KM2 although they sometimes have 285/75R16 Mickey Thompson ATZ Interestingly, my 2001 110 did a gearbox at 50,000 miles. That truck was driven 'unsympathetically' off-road though regards Ian |
22nd Mar 2012 8:14am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17344 |
'07' plate DC, used daily including off-road, usually laden near GVW, coming up to 100k miles, on original gearbox and transfer box with no issues from either.
Several other driveline issues (front diff, rear halfshafts) and early-type clutch replaced with later type. Main dealer did once advise I needed a new t-box due to backlash, but it was actually the front diff not the t-box, and I wonder how many other Puma 'gearbox' issues are in fact caused by other driveline components. Overall I rate a good MT82 as the best Landrover gearbox since LR fitted synchro to 1st and 2nd gear; I'd certainly rather have an MT82 than an R380 any day. |
22nd Mar 2012 8:29am |
