Home > Puma (Tdci) > Rear Side Window Grills |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
I have a mantic internal rear window guard on my 110 USW and I think it looks pritty good, it fits nice. Neatly and it's black. I also have no issues looking in the rearview mirror through the load guard and the window guard Russell
2011MY 110 XS USW Black |
18th Mar 2012 2:32pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Mobile storage system's ones are on the inside and have a hole to allow window opening with ease.
18th Mar 2012 2:34pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
agree - these are realy good bits of kit and fit really well Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
18th Mar 2012 4:24pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20497 |
Keep them on lead tied down or chain. (loose of course) |
18th Mar 2012 4:31pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Correct,, but the "hole" for window opening is only about 2" ,, and watch your fingers if the window is stiff California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
18th Mar 2012 5:29pm |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
I do not like the attention they attract and personally think there are already enough holes that are leaking/causing corrosion.
So i solved the jumping dogs, corrosion, ridiculous pricing syndrome and the opening of the side windows with a 40 euro ikea visit. :) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
18th Mar 2012 7:00pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Ventilation for dogs?
Minimum requirement would be a pair of these on rear side doors Cost of £39/pair OK, I am not sure if those would be sufficient for dogs in really hot weather External rear side window grilles like these Fitting externally this grill will secure the rear window of your Land Rover Defender. Designed to fit neatly and providing full window coverage for the Defender this grill is constructed from 2mm mild steel and is zinc and powder coated black. Each grill is equipped with 8 brackets to attach it to your vehicle when out and about in the UK or travelling through the continent on expedition. Allow your rear side windows to be fully open. We can supply these for about £115 External window grilles as supplied to and fitted by a fellow forum member Click image to enlarge Brendan Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by leeds on 18th Mar 2012 7:32pm. Edited 1 time in total |
18th Mar 2012 7:06pm |
I have the external rear grills (ask Leeds for the good ones ) They are be brilliant for the dogs and can be opened/closed fully and easily from inside... but look a bit "serious":
Click image to enlarge Personally, I don't care as my 110 looks a bit mean anyway Please note: old photo - chequerplate, rivets, wheels etc. are now all black Matt Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
18th Mar 2012 7:30pm |
BBSJK Member Since: 12 Sep 2009 Location: Ledbury, Herefs Posts: 100 |
The vents that slide into the rear windows work very well and are fully waterproof. Give supprising good ventilation and fit nicely under the rear seat. Would not be good for a hot day to leave to dog in the car.
JK No the other left . . . |
18th Mar 2012 9:08pm |
xatzhs Member Since: 12 Dec 2010 Location: Northumberland & Down South Posts: 258 |
Ze, those look very nice indeed. Although how are they attached? It looks like they're drilled on from here?
Are there any which could be a semi-permanent feature on the exterior? |
18th Mar 2012 9:20pm |
They're riveted from the outside (wet-assembled with sealant, also to prevent corrosion). However, I'm considering drilling them out sometime and using rivnuts with security screws, so they can be removed occasionally for re-painting etc. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
18th Mar 2012 10:07pm |
The Musketeer Member Since: 07 Feb 2012 Location: United Kingdom Posts: 193 |
Do you do them for just the rear three windows (for a hardtop)? Interior ones would be better though. Sam Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Good things come to the wild and free |
18th Mar 2012 10:41pm |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
The ones I have seen tend to rattle - The ones above look as though they probably don't because they are secured differently. Would I be correct in saying that?
19th Mar 2012 8:58am |
Hi Sam, yes we can supply them, for the three rear window. The rear side window grilles can be fitted either internal or external.
Rear door window grill (internal) £62 Small rear window grilles x 2 (internal/external) £67 Side window grilles x 2 (external) £112 Carriage extra if required. HTH Brendan |
19th Mar 2012 9:24am |
