Home > Puma (Tdci) > Rear Side Window Grills
Page 2 of 2 <12
ZeDefender
wslr wrote:
The ones I have seen tend to rattle - The ones above look as though they probably don't because they are secured differently. Would I be correct in saying that?
Mine don't rattle at the mounting points. At first they did rattle against the windows a bit when the doors were slammed but I just pulled them out a tad to give some clearance. All now okay Thumbs Up Tell someone you love them today because life is short.
Post #132528 19th Mar 2012 12:49pm
wslr
Is that yours in the photo on page 1? Are they easy to fit without damaging anything?
Post #132545 19th Mar 2012 1:27pm
JWL
Mine rattled at first, they came from Simmonites a few years ago, so I took them off and put some foam backed tape on the upright flats where there's no fixing points. Mine are starting to rust where the paint covering has been "battle scarred" over the years but some of the "dings" just prove to me that they were worthwhile putting on in the first place Thumbs Up
Post #132546 19th Mar 2012 1:27pm
ZeDefender
Yup - it's the blue 110. They are easy to fit as long as you can drill holes accurately and are careful and firm with the riveter. Wet assemble with sealant for a nice weatherproof fit.
On the other hand, if you consider drilling rivet holes as "damaging", they might not be for you Whistle
p.s. just remembered - like JWL, I put some edge protector on the uprights to keep them pressed gently against the side Thumbs Up Tell someone you love them today because life is short.
Post #132550 19th Mar 2012 1:48pm
ZeDefender
Okay - finally fitted my rear grille:
The rear door plastic trim in the Puma is substantial and once removed it didn't seem practical to start chopping it up, so I trimmed the bottom of the grille so it would sit tight on top of the trim. Also cut a hole for the stop light (I ordered the wrong one Rolling Eyes):
Marked the holes, pre-drilled with a small bit (like an idiot I didn't use a drill stop and managed to punch the outer skin - more touching up Rolling Eyes Used M6 rivnuts:
Fitted the grille with M6 screws:
Fitted "anti-rattle" edge-trim at the top:
View from the back:
View from inside (looks dark inside but isn't - bad camera):
Tips (hope this is right): treat drill holes (I also treated the skin in places Embarassed ) with KuRust etc. and use Duralac etc. on the alu rivnuts (steel door). Also squirted ACF-50 through the fitted rivnuts onto the skin (can't hurt) and onto the screws before assembly.
One final tip is to figure out where there may be vibration and deliberately warp the grill so it doesn't touch the door (using more edge-trim would also work. Sorry if I've forgotten anything - Hell breaking loose here.
Matt
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #133125 21st Mar 2012 3:45pm
miguel555
Spain 2002 Defender 110 Td5 CSW Alpine White
leeds wrote:
Hi Sam, yes we can supply them, for the three rear window. The rear side window grilles can be fitted either internal or external.
Rear door window grill (internal) �62
Small rear window grilles x 2 (internal/external) �67
Side window grilles x 2 (external) �112
Carriage extra if required.
HTH
Brendan
Hi leeds, do you still supply these grilles?
Post #833198 24th May 2020 10:10pm
izack98
Canada 2001 Defender 110 2.5 TD CSW Chawton White
I'm interested as well.
Post #833212 25th May 2020 4:41am
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
I know this does not help, but I can't help it - these window grills always remind me of something between prisoners transport and MadMax. Never forget: cars have owner, Landrover have field service personnel.
Post #833220 25th May 2020 6:00am
Brendan (leeds) doesn't seem to come on here anymore. You could always have a look at his company website though - 4x4 Overlander. Darren
Post #833239 25th May 2020 7:38am
Page 2 of 2 <12
