Home > Puma (Tdci) > TDCI Engine Spares |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
fixit
generally there are several part worn engines from transits and pumas on e/bay may be a cheeper and easier way to go DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
16th Mar 2012 6:08am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Don't need to fix it, Fixit! I have a solution
Welcome to the forum :wink: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
16th Mar 2012 7:34am |
fixit Member Since: 15 Mar 2012 Location: Sunny devon Posts: 66 |
Ah a 110 for work if only I could get all the tools in I would have a
110 utillity tomorrow This one is one of my engineers so could do with it back on the road Its just a bit peaving that ford won't sell the parts when we are more than capable of repairing it Thanks for the welcome you will see plenty more of me now in here |
16th Mar 2012 8:54am |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Hi Chris: Microcat is showing LR004453 (Grade H), LR004454 (Grade I) and LR004455 (Grade J) as the con rods on the 2.4 They are retailed at £82.08 + VAT each.
LR004411 are the big end bearings are are £13.62 each. Still think Zag has the right idea though. |
16th Mar 2012 9:24am |
Click image to enlarge Click image to enlarge Price in €s Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
16th Mar 2012 9:31am |
Thanks for the help I have ordered the parts today
With a bit of luck they will be here tomorrow so I will let you know how we get on on Monday As long as the rod is the same and I see no reason why not you should have saved me nearly £1350 before dinner Just a few more savings like that and should be able to afford that 110 |
16th Mar 2012 10:54pm |
17th Mar 2012 1:14am |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 |
Good luck, but you may find a Defender Crank shaft and Con rods are different from a Transit engine due to the change in Torque characteristics between the two models.
Open the packaging carefully, then at least you can return them if they don't fit. Richard Either a 90, 110 or 130. Discovery 5 |
17th Mar 2012 3:11am |
I was hopeing they would be the same I will let you know either heat
My rod had an I stamped in it so ordered that one With a bit of luck I will know later Cheers |
17th Mar 2012 7:47am |
hi fixit
any idea how/why the engine blew up? what sort of mileage does it have ? any other mechanical issues with parts common to the defender ? all info much appreciated by us cheers bp |
17th Mar 2012 8:01am |
Hi all we have had a couple of probs up till now but nothing major
Ford supplied the wrong timing chain And when we fitted the rear crankshaft oil seal it got nicked So with a bit of luck we should have a working engine by tomorrow The con rod is spot on it seems so the only parts that wasn't ment to work is fine In answer to the questions it has done 100k miles has full service history alll from ford apart from the last one And there is no reason that we can find the explain why it happened We have owned it from new so we know its all right So i can only hope all will be ok when it goes back in There is also a leaking blanking plug in the front of the gearbox to sort now its out Thanks agin for the help |
20th Mar 2012 10:20pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
wonder why this has rear side steps fitted ? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
21st Mar 2012 11:17am |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 |
Come on Grockle, get that grey matter working. It's so you can reach the seam in the roof and repair the leaks |
21st Mar 2012 3:06pm |
You would be better of with running boards so you could get an even bead of sealant down the whole lenght
Or you could just tar the roof from them There must be a reason why we can't enough of them |
21st Mar 2012 7:54pm |
