Home > Puma (Tdci) > TDCI Engine Spares
fixit
TDCI Engine Spares
Hi lads sorry this is my first post and i am on the want Embarassed
Basically i have a transit with a blown engine and ford tell me they wont/can't sell me a conrod and bigend bearings
they want to sell me a short engine at the cost of £1540
So we have been thiking as the puma engine is a transit engine may be landrover would sell us the bits
So i am hopeing one of you may know if the conrods and bigends are avaliable for a puma engine from landrover
Thanks Chris
Ps i am an avid landrover fan with a 90 and a disco3 and have been reading for a while Cool
Post #131740 15th Mar 2012 9:36pm
LR90XS2011
fixit
generally there are several part worn engines from transits and pumas on e/bay may be a cheeper and easier way to go DEFENDER 90 TDCI XS,
Post #131760 16th Mar 2012 6:08am
Zagato
Don't need to fix it, Fixit! I have a solution Very Happy
Welcome to the forum :wink:
Post #131764 16th Mar 2012 7:34am
fixit
Ah a 110 for work if only I could get all the tools in I would have a
110 utillity tomorrow Razz
This one is one of my engineers so could do with it back on the road
Its just a bit peaving that ford won't sell the parts when we are more than capable of repairing it
Thanks for the welcome you will see plenty more of me now in here Very Happy
Post #131779 16th Mar 2012 8:54am
wslr
Hi Chris: Microcat is showing LR004453 (Grade H), LR004454 (Grade I) and LR004455 (Grade J) as the con rods on the 2.4 They are retailed at £82.08 + VAT each.
LR004411 are the big end bearings are are £13.62 each.
Still think Zag has the right idea though. Laughing
Post #131791 16th Mar 2012 9:24am
dgardel
Italy
Price in €s
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #131792 16th Mar 2012 9:31am
fixit
Thanks for the help I have ordered the parts today Thumbs Up
With a bit of luck they will be here tomorrow so I will let you know how we get on on Monday
As long as the rod is the same and I see no reason why not you should have saved me nearly £1350 before dinner Thumbs Up
Just a few more savings like that and should be able to afford that 110 Whistle
Post #131984 16th Mar 2012 10:54pm
dgardel
Italy
Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #131989 17th Mar 2012 1:14am
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Good luck, but you may find a Defender Crank shaft and Con rods are different from a Transit engine due to the change in Torque characteristics between the two models.
Open the packaging carefully, then at least you can return them if they don't fit. Big Cry Richard
Either a 90, 110 or 130.
Discovery 5
Post #131993 17th Mar 2012 3:11am
fixit
I was hopeing they would be the same I will let you know either heat
My rod had an I stamped in it so ordered that one
With a bit of luck I will know later
Post #132000 17th Mar 2012 7:47am
hi fixit
any idea how/why the engine blew up?
what sort of mileage does it have ?
any other mechanical issues with parts common to the defender ?
all info much appreciated by us
cheers
bp
Post #132002 17th Mar 2012 8:01am
fixit
Hi all we have had a couple of probs up till now but nothing major
Ford supplied the wrong timing chain Shocked Rolling Eyes
And when we fitted the rear crankshaft oil seal it got nicked Embarassed
So with a bit of luck we should have a working engine by tomorrow
The con rod is spot on it seems so the only parts that wasn't ment to work is fine Thumbs Up Thumbs Up
In answer to the questions it has done 100k miles
has full service history alll from ford apart from the last one
And there is no reason that we can find the explain why it happened
We have owned it from new so we know its all right
So i can only hope all will be ok when it goes back in
There is also a leaking blanking plug in the front of the gearbox to sort now its out
Thanks agin for the help Very Happy
Post #132990 20th Mar 2012 10:20pm
Grockle
Welcome to the forum Wink
wonder why this has rear side steps fitted ?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #133081 21st Mar 2012 11:17am
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
Come on Grockle, get that grey matter working.
It's so you can reach the seam in the roof and repair the leaks Rolling with laughter
Post #133122 21st Mar 2012 3:06pm
fixit
You would be better of with running boards so you could get an even bead of sealant down the whole lenght Rolling with laughter Rolling with laughter Rolling with laughter
Or you could just tar the roof from them Laughing
There must be a reason why we can't enough of them
Post #133194 21st Mar 2012 7:54pm
