Home > Maintenance & Modifications > Seat rails - fitting
Gamekeeper
Just ordered some of those seat rails. Does the Dedender have captive nuts or do I need to line up another pair of hands to help me bolt them on? 16 Land Rovers so far....currently a 110. Oh and a Ducati, a Montesa, a Kawasaki and an understanding wife!
Post #130608 11th Mar 2012 8:08pm
bolampau
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Re: Seat rails - fitting
Nah, pretty straight forward to fit, you shouldn't need any help/assistance.
Post #130609 11th Mar 2012 8:11pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi,
Really basic to do, can supply a photo of finished result if needed...
Jack
Post #130658 11th Mar 2012 10:55pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
yep, easy one but when i fitted my mud rails the rear bolts were'nt long enough and i had to buy some longer ones. BM52
Post #130659 11th Mar 2012 11:05pm
Gamekeeper
Rails came today. 10mins to fit. Brilliant mod. I'm 6ft 2. 16 Land Rovers so far....currently a 110. Oh and a Ducati, a Montesa, a Kawasaki and an understanding wife!
Post #131093 13th Mar 2012 8:15pm
Gamekeeper
Now I need a slim door handle to stop my knee rubbing - any suggestions other than make my own? 16 Land Rovers so far....currently a 110. Oh and a Ducati, a Montesa, a Kawasaki and an understanding wife!
Post #131098 13th Mar 2012 8:20pm
bolampau
I'm 6ft 5 and without rails I'd really struggle to drive, so definitely the best mod I've fitted by far!
Post #131099 13th Mar 2012 8:20pm
bolampau
Here you go....
http://www.mudstuff.co.uk/Defender%20Flexi...ndle.shtml
they are excellent!
Cheers,
Paul
Post #131101 13th Mar 2012 8:22pm
Gamekeeper
bolampau wrote:
Here you go....
they are excellent!
Cheers,
Paul
Ordered - Cheers! 16 Land Rovers so far....currently a 110. Oh and a Ducati, a Montesa, a Kawasaki and an understanding wife!
Post #131105 13th Mar 2012 8:28pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
13mm socket and thats it!
Real easy job to do, i fitted both XS seats into my 90 last weekend, probabally the easiest job so far!
Post #131109 13th Mar 2012 8:32pm
JWL
I have made some rails for mine and last week I modified them by welding some more fixing points on them to move the seat over by 1 1/2" to take the driving position off the door pillar. I've driven about 300 odd miles now, both a long trip and a few shorter trips, seems to work just could do with shifting the steering wheel over a bit Whistle
Post #131156 13th Mar 2012 10:16pm
bolampau
Hi JWL,
have you got photos of the mod?
Cheers,
Paul
Post #131258 14th Mar 2012 10:26am
JWL
Sad as I am I do Whistle In this day and age of cameras on phones I've begun to take pictures of everyhing when I dismantle and modify mainly to jog my memory on what I did and to refer to when I put it back together, bit easier than those notes scribbled on the back of a fag packet that you then go and throw away Rolling Eyes
First how much the original rails lift the seat;
Just using a simple bit of box section;
The hole at the top/front is to allow the original bolt and socket through, the next one down is the original bolt hole which moved the seat rails back and then the tab welded on the side allows the seat to be fixed away from the door;
Just to show how far back the seat has moved, the sideways movement is about 45mm;
This is just to show the cutout required towards the reat to allow the box to clear the seam on top of the seat box, just be aware that on 110's, well my station wagon the door pillar has a angled strengthening brace that fouls the box section which can take a tap from a hammer or take some more out of the box section to allow clearance. I did put the original washer/spacers under the box when I put the rails in as it allowed better clearance over the sound matting;
Seat refitted;
Close up of front;
Close up of back showing that curved stengthening brace;
Hope that helps if anyone else wants to give it a try, really easy thing to do as long as you can stick bits of metal together and drill holes in the stuff.
Post #131270 14th Mar 2012 11:12am
bolampau
Thanks JWL,
I'm gonna consider it for my 110.
I'm no good at welding but could get it done locally though.
Cheers,
Paul
Post #131279 14th Mar 2012 12:01pm
JWL
Didn't say I was good at welding Laughing I just can and grinders/paint are just great Thumbs Up
Post #131281 14th Mar 2012 12:05pm
