Home > Technical > Wading with wet alternator and electrics! |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5700 |
Thinking wading depth is due to the air intake for the engine, not for the electronics/electrics.
Andy |
4th Mar 2012 1:19pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Not to mention water entering the fuel tank vent pipe beneath the rear wheel arch
4th Mar 2012 1:22pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
land rover insisted that the ECU in the engine compartment was water proof until they emptyed it of all the welsh water I had smuggled across the boarder
the big issue with the alternator is mud, best advice seems to WD 40 before and after, killed two alternators in the first two years, but non since, funny how things change when your warrenty runs out Mark |
4th Mar 2012 2:30pm |
have a close look in the underseat boxes especially in the corners ... more holes than an aero
mines all filled now i have sealed batteries... although interestingly the genuine LR battery had a breather pipe that poked outside the box.... not sure if thats good or bad for wading |
4th Mar 2012 4:03pm |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 |
slightly but when i looked in my battery box, i come across the breather pipe for the battery - one end of it went outside and the other end seems to have come adrift i presume it goes onto the battery and not onto the tray, but i couldnt find where it should go, any ideas?? thanks, Harry |
4th Mar 2012 4:11pm |
small hoes either side (short sides) towards the top .. |
4th Mar 2012 4:15pm |
4th Mar 2012 4:17pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
i think we were wading around the LR max on the wales weekend. No issues and sitting in the stream washed the chasiis clean
4th Mar 2012 4:47pm |
