Home > Technical > Rear Diff issues
Blaserman
England 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Rear Diff issues
Hi Guys
Just wondering if anyone else has experienced any rear diff issues and if so what was causing it?
My car is 12 months old having just turned 14k and has just eaten its 5th rear diff!!! The rear prop has been tested by a specialist and found to be perfect! Shocked
I am waiting for LR to get back to me with a plan but wondered if anyone else had any similar issues.
Cheers Rob
Post #125806 22nd Feb 2012 3:12am
have you lifted the truck ? if not and the prop is perfect, then i'd get it checked by a specialist ... either somethings not lined up or they are bodging the diff repair each time.
did the garage say exactly what went wrong with the diffs each time ?
did you try a search on the forum for similar?
Post #125812 22nd Feb 2012 8:25am
Tim_NZ
Australia
I would insist they change the whole rear axle assembly. It sounds like the axle tube is bent, or the diff is not fitting parallel with the axles.
Good luck! Smile
Tim
Post #125824 22nd Feb 2012 9:44am
Naks
Re: Rear Diff issues
Holy mothballs! that must be some record Sad
Yeah, sounds like it's another issue that's causing the diff to fail. --
Post #125827 22nd Feb 2012 9:59am
Blaserman
Thanks for the responses guys.
bpman the truck is not lifted i have changed the tyres but thats the only thing that could cause problems with the drive train.
Naks cheers for the PM LR are aware of it and working on a plan. If 5 diffs is boardering a record then the fact that its chewed the latest one up in less than 150 miles has got to be!!!!
Tim_NZ that is my next line of thought, they put the last 2 down to a collapsed half shaft bearing but since that has been replaced it should be working fine!
Post #125864 22nd Feb 2012 12:11pm
BigMike
A half shaft bearing shouldn't cause diff failure. I agree with the others, there is something else going on here. I'm surprised that LR would just keep approving diff replacements via the dealer like that without some further investigations. And that the dealer just kept on replacing it without investigating more.
Post #125871 22nd Feb 2012 12:33pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I'm not Rolling Eyes
Post #125878 22nd Feb 2012 1:12pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Rejection and new vehicle Thumbs Up
Post #125885 22nd Feb 2012 1:56pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I had diff problems on my td5 and the rear axle tube was bent I got a new axle tube put it at the side of the old one and it was like a banana !!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #125891 22nd Feb 2012 2:17pm
Blaserman
To be fair the dealer is as annoyed as me. LR dont seem to want to locate the issue instead they just keep throwing diffs at it. However a diff every 3 days may have them change thier minds.
Post #125971 22nd Feb 2012 8:30pm
wslr
I know Defender diffs were bad, but not this bad... Confused
Post #126052 23rd Feb 2012 12:33am
Alive Tuning
I had a call from Duckworth the other day, telling me there has been a recall regarding the diff oils. They wanted my 61 plate 90, and not the 11 plate 110 though. Confused
Post #126073 23rd Feb 2012 7:54am
T1G UP
Mines in fort a bit of warrenty work and has the rear diff has a whine on overun...not bad but audible? Best mention it.
Post #126218 23rd Feb 2012 8:07pm
Blaserman
If that whine is bearable leave it alone!!! Mine went in 6 months ago with the same whine but alot louder, they went through 4 diffs to find one that didn't whine and even then it makes slight noise, well did its was a sort of clunk clunk clunk again within 2 weeks of putting it in bit like this one at the moment!!!!!!
Post #126902 26th Feb 2012 6:17pm
