![]() | Home > Technical > Rear Diff issues |
have you lifted the truck ? if not and the prop is perfect, then i'd get it checked by a specialist ... either somethings not lined up or they are bodging the diff repair each time.
did the garage say exactly what went wrong with the diffs each time ? did you try a search on the forum for similar? |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
I would insist they change the whole rear axle assembly. It sounds like the axle tube is bent, or the diff is not fitting parallel with the axles.
Good luck! ![]() Tim |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2652 ![]() ![]() ![]() |
Holy mothballs! that must be some record ![]() Yeah, sounds like it's another issue that's causing the diff to fail. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Blaserman Member Since: 23 Sep 2008 Location: Herefordshire Posts: 46 ![]() ![]() ![]() |
Thanks for the responses guys.
bpman the truck is not lifted i have changed the tyres but thats the only thing that could cause problems with the drive train. Naks cheers for the PM LR are aware of it and working on a plan. If 5 diffs is boardering a record then the fact that its chewed the latest one up in less than 150 miles has got to be!!!! Tim_NZ that is my next line of thought, they put the last 2 down to a collapsed half shaft bearing but since that has been replaced it should be working fine! |
A half shaft bearing shouldn't cause diff failure. I agree with the others, there is something else going on here. I'm surprised that LR would just keep approving diff replacements via the dealer like that without some further investigations. And that the dealer just kept on replacing it without investigating more.
I'm not ![]() |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Rejection and new vehicle
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 ![]() ![]() ![]() |
I had diff problems on my td5 and the rear axle tube was bent I got a new axle tube put it at the side of the old one and it was like a banana !!
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
To be fair the dealer is as annoyed as me. LR dont seem to want to locate the issue instead they just keep throwing diffs at it. However a diff every 3 days may have them change thier minds.
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
I know Defender diffs were bad, but not this bad...
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
I had a call from Duckworth the other day, telling me there has been a recall regarding the diff oils. They wanted my 61 plate 90, and not the 11 plate 110 though.
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
Mines in fort a bit of warrenty work and has the rear diff has a whine on overun...not bad but audible? Best mention it. |
If that whine is bearable leave it alone!!! Mine went in 6 months ago with the same whine but alot louder, they went through 4 diffs to find one that didn't whine and even then it makes slight noise, well did its was a sort of clunk clunk clunk again within 2 weeks of putting it in bit like this one at the moment!!!!!!
