![]() | Home > Td5 > TD5 110 Starting issues |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 328 ![]() ![]() ![]() |
Several things come to mind:-
The battery may have just (coincidentally) died or developed a high resistance internal joint at one of the terminal posts due to stress if the cable clamps were not slackened whilst the battery was being moved. Check voltage across it when starting, ideally should be more than 10 volts. Check the continuity of the earth lead for the main battery, it may have fractured when moving the battery. Check the battery is charging OK with the engine running, voltage across the battery should be 13.6 volts or more. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 ![]() ![]() ![]() |
When I last checked the battery it was pumping out 14.x volts while the engine was running.
I do have a spare battery that was originally in the car which is show 12.5v on the bench. I could rule out the earth by connecting another earth direct to the starter housing My other thought is maybe I have bad relay or maybe a bad lead that activates the solenoid? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17588 ![]() ![]() ![]() |
If the engine was running you would have been measuring the alternator output rather than the battery - you could quite possibly have a battery fault and still get this reading. Since from what you say you generally seem to be able to start the car if you bypass the normal connections between the battery and starter, and since your problems seemed to start when you moved the battery, I suggest that the starting point for your investigation should be the battery connection and lead on the feed to the starter motor. How is your winch/Anderson connector wired to the battery? |
derekt Member Since: 28 Dec 2011 Location: Aberdeen Posts: 7 ![]() ![]() ![]() |
Classic symptons of starter solenoid contacts. These can be repaired see http://www.ebay.co.uk/itm/LANDROVER-DISCOV...3ad534e4c.
Quite a simple job, only the top bolt on the starter can be a b**gger to access! Adventure before Dementia |
Oops, just re-read your first post! Starter solenoid already replaced.. Next place to check is the relay under the driver seat next to the ECU. Adventure before Dementia
BlackWolf:
Winch is wired to the main vehicle battery with a kill switch on the positve feed mounted on the battery box. Anderson connector is wired into the positive feed and negative feed at the winch end Will measure the battey tomorrow and see what the standing voltage is. DerekT Is that the yellow relay in the seat box? Are there two relays for the starter, 1 under the seat and 1 behind the removable panel by the gearstick,? Can I replace these with standard 4 pin relays? And yup the 15mm bolt was a PITA to get to for the starter. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Forgot to test the battery voltage.
![]() The car started first turn of the key today. Took it for a spin and all was good, even restarted at least twice after being left to stand. In a way I didn't want the car to start as it makes life a bit more difficult to trace the fault. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Checked the battery voltage and that was 12.6/12.6v after standing.
I have cleaned up, and checked & tightened the earth and positive wires and made the solenoid connector a better fit by crimping it and also cleaned the contacts on the starter relay's (the one by the gearstick fuse box and under the seat) Fingers crossed. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Car played up again today.
Started OK, after sitting all night. Went out, did about 5 miles of running around. Parked up. came back to the car about 30mins later, long crank - but no start. Checked voltage at the solenoid wire, 11.9v, checked voltage at the anderson plug 12.5v. Gave up and went fishing on the boat. Came back about 2.5hrs later, first turn of the key and brum! like nothing was wrong. This is getting annoying now. Off the top of my head, the only sensor on the engine that will stop the car from starting is the Crank Sensor (CKP?). Any other thoughts people? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
I know aftermarket starters can cause interference of the crank signal wire, even though the wire is screened. Perhaps this is the issue you have?
Anyone with a Picoscope near you? You could check the crank sensor waveform is being seen at the engine ECU when cranking. |
Check the fuel pump relay under the driver's seat.
The voltage drop caused by cranking sometimes stops it closing properly, it just chatters. A finger on top will sense whether it's chattering or not. Check it's socket contact also. ![]() |
The best I could do is someone with Testbook & Nanocom?
Which is the relay for the fuel pump? Is it under the drivers seat or with the other relays by the gearstick? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
It's the second from the rear yellow relay. You may have between two and four according to your model. Try changing it with another. ![]() |
Cheers. I will have a look. 1999 Defender TD5 110
