![]() | Home > Maintenance & Modifications > SHOCKS & SPRINGS |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 ![]() ![]() ![]() |
i have an svx, very stiff, a little roll, but not as much as i have seen on other defenders. Cheers
keith puer claudius |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Try driving 100 miles of unsurfaced tracks at speed with no load in the back and you will find out why land rover dont fit as standard.
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Landrover do give you a choice when you purchase, ie HD springs upgrade for those who need it.
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I have the Bearmach HD springs on my Discovery and they are a dream on unsurfaced tracks. I would even say that it is better than the standard 'soft' suspension. I will be upgrading mine in the future (once warranty is out). When I did my time in the jungle in Belize, I would kill for the old Bedford truck which had rock solid suspension compared to the newer Daf trucks that had softer suspension. Glyn |
shorty Member Since: 31 Oct 2008 Location: Hillcrest, Kwa Zulu Natal Posts: 160 ![]() ![]() ![]() |
After fitting after market shocks and springs on my prev puma I was quite surpised at how well the stock setup works on dirt road conditions. Sure you can feel it's a softer ride but for me it's perfect as I rarely load up my 90. I think I'm going to leave the setup as is. I have a sneaky feeling that the after market setup on my prev puma was a contributing factor for the faulty 3 front diffs & 2 rear diffs. Let's see, only time will tell. Land Rover's don't leak oil, they simply mark their territory!
Zinke to be honest id rather drive with this set up than standard on unsurfaced tracks you would as well if there was two of us out and you was in a rig with standard set up and then jumped in mine and felt the difference believe me iv noticed the difference when driving over cobbles the rig with standard set up used to rattle to bits now nothing so much smoother ![]() |
Pauly Member Since: 19 Jun 2008 Location: Dresden Posts: 11 ![]() ![]() ![]() |
Hi Folks,
any experience with the terrafirma 2" lift kit on a 110 Puma? Thanx Pauly All science is either physics or stamp collecting. (E. Rutherford) |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2462 ![]() ![]() ![]() |
I did not hear good comments. I finally got OME´s Puma 110" SW ............................................................. Earth first. Other planets later |
