Home > Maintenance & Modifications > Drooping wings
shorty
South Africa 2009 Defender 90 Puma 2.4 XS CSW Chawton White
Drooping wings
Hi guys. I got my brand new replacement 90 last week from LRSA. When I was fitting the wing top checker plate and headlight grills this afternoon I gavemyself I slight heart attack. As usual once I fit somthing I like to stand back and admire the view but was shocked to see that the headlight grill was skew. How could this be? I measured,re measured and measured again before drilling. I pulled out the measuring instruments againand was quite shocked to find that the entire wing has been mounted skew. Is this a job I can do with not to much effort or should I tell LR to fix or am ibeing fussy? I'll post some pics on Monday. Land Rover's don't leak oil, they simply mark their territory!
Post #12408 27th Jun 2009 7:48pm
Grockle
Shorty take it back,don't mess with it get the dealer to sort it,and no your not being fussy I'd be just the same. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #12414 28th Jun 2009 9:25am
AndrewS
Yep take it back Thumbs Up
Post #12427 28th Jun 2009 1:23pm
MK
I bet it is the left wing. Take it back for sure. Puma 110" SW
Post #12429 28th Jun 2009 4:30pm
shorty
Cheers!
I'll take it back in the morning. It's the drivers side wing that droops the worst ( rhd ). Land Rover's don't leak oil, they simply mark their territory!
Post #12431 28th Jun 2009 6:22pm
shorty
let me know if you can notice it?
Post #12441 29th Jun 2009 7:58am
bustduster
Even after ten pints my droop wouldn't be as bad as that!!
Post #12442 29th Jun 2009 8:17am
Grockle
It is noticeable. 2.4 90 XS
Post #12444 29th Jun 2009 8:44am
shorty
LR have loaned me a disco and sent the defender to the body-shop. Does anybody know if its a case of bending it into shape with force or will they have to remove and refit? is it riveted on or spot welded? Land Rover's don't leak oil, they simply mark their territory!
Post #12463 29th Jun 2009 11:36am
Grockle
Loosen the mounting bolts and realign should be all it needs 2.4 90 XS
Post #12465 29th Jun 2009 11:49am
shorty
hopefully it will be done in a jiffy then!! Thumbs Up Land Rover's don't leak oil, they simply mark their territory!
Post #12468 29th Jun 2009 11:56am
shorty
just out of interest. Does anybody have a haynes exploded view of how a front wing is mounted or any other similar illustrations. Im interested to know what the butchers (panel beaters) are up to?? Land Rover's don't leak oil, they simply mark their territory!
Post #12555 1st Jul 2009 11:16am
NoDo$h
LHS on ours has a slight droop, although not as bad as that. I put it down to the charm of owning a Defender.
I managed to get the roof back on straighter than when it came out of the factory after we sold the soft top earlier this year. I suspect I might have taken a little longer over it than two hairy brummies in the factory though
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #12558 1st Jul 2009 11:54am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Just had mine straightened our on first service, wasn't quite as pronounced as this one, but is now spot on.
So it can be easily sorted by the dealers, a bit of arm twisting may be required.
Don't take any notice of the 'they are all like that sir' I didn't see any in the land rover promotional shots that were droopy, although nearly all of the new ones in the showroom/display were out to various degrees.
Take it back and be nice - that seemed to get a good result.
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #180866 1st Nov 2012 8:54am
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
Why does this only seem to affect Puma's? I didn't think they were built any different to Td5's, Tdi's, etc, etc.
Post #180870 1st Nov 2012 9:15am
