Home > Maintenance & Modifications > Oil Seepage into ECU via injector Loom Query |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Someone correct me if im wrong - ive not met anyone after the loom change that actually as suffered this again.
Did you clean it all out before fitting the new one. Mike |
21st Jun 2009 3:07pm |
Landy nut Member Since: 22 Dec 2007 Location: In hiding Posts: 154 |
Did you replace the seals and in particular, the main one which gives the trouble at the front of the block??
21st Jun 2009 3:45pm |
Bruce S Member Since: 20 Jun 2009 Location: Stoke on Trent Posts: 17 |
The injector loom was sold as one piece.
Landy nut - What are the seals that you are referring to, have I missed the obvious? |
21st Jun 2009 4:21pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8113 |
theres a seal in the block that the wire passes through - some people leave it out on refitting the new loom. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
22nd Jun 2009 4:37pm |
SteveNorman Member Since: 16 Sep 2008 Location: Somerset Posts: 18 |
The loom (AMR6103) comes with the two seals on it.
I expect the problem you have is residual oil in the loom causing poor connection at the ecu end. Take off the red ecu connector & reclean out, I use an aerosol cleaner & then electrical contact cleaner. It may take a few attempts as the residual oil in the loom keeps making it's way to the ecu. I have had to change a few complete engine looms on discovery 2 for the same problem, (although very rare they need it). HTh Regards Steve |
22nd Jun 2009 7:42pm |
