Home > Maintenance & Modifications > wiring help
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
wiring help
i have a remote spot light very powerfull which is i think off a army vehicle its wirered up to work off the cig socket.
it gets so hot im afraid it will melt the wiring. Shocked
on the lens it has CE 4/00
12 MARINE 13V
anyone know this light or how i could test it.
[/img]
Post #120290 1st Feb 2012 11:29am
tolley
just had aonther look it might be CE 4700 the severn not so clear.
Post #120291 1st Feb 2012 11:33am
ZeDefender
Borrow a multimeter to test the current draw and then check/guess the wire (conductor) x-section area and see if it's sufficient. Bear in mind free cables can take more current than bundled ones without overheating and the insulation type can be a factor too. Quick internet search should find a table of conductor diameter or area vs current.
Matt Tell someone you love them today because life is short.
Post #120293 1st Feb 2012 11:42am
ZeDefender
If you can't get a multimeter, divide the bulb wattage by 13 and add 10% Tell someone you love them today because life is short.
Post #120294 1st Feb 2012 11:45am
tolley
thanks
http://www.magnalight.com/pc-818-38-hid-re...se.aspx###
found this which is a close match.
Post #120295 1st Feb 2012 11:54am
ZeDefender
tolley wrote:
thanks
Er...wow! Not cheap then Shocked Thumbs Up
If it's HID probably best measure current directly (35W bulb on 24V system should draw less than 2 Amps but I'm not sure about those bulbs). In any event HID is basically an arc lamp so the bulb itself will get very hot in any case.
The ciggy socket should be fused (check it's not been bridged if the vehicle is second hand!) so would blow if there are current/heating issues at the Landy-end.
Looks like a really nice light Very Happy Tell someone you love them today because life is short.
Post #120310 1st Feb 2012 1:30pm
Happyoldgit
Sure it's not a conventional GE sealed beam? Steve.
http://forums.lr4x4.com
Post #120312 1st Feb 2012 1:38pm
tolley
zedefender thanks
only cost me £30 from sodbury sort out.
its got made in the USA so might be the same.
Post #120319 1st Feb 2012 2:05pm
K9F
The wiring doesn't look 'too clever' on the lamp. Pop the filament/bulb/lamp out and somewhere there should be a wattage and voltage mark. If you have/have access to an insulation tester test the lamp wiring out with the filament/bulb/lamp removed.
The cigarette socket should be protected by a 20 amp fuse.
Therefore the maximum rating before the fuse will blow will be 12 volts x 20 amps = 240 watts. The wires will get hot as you have effectively a quarter killowatt fire on the go. If the wire insulation does melt the fuse will be the next to go. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #120441 1st Feb 2012 8:28pm
tolley
i took the wiring apart to check the connection hence the look,the first part of the wiring is original from the conection block it is off a roto light/remote ,will have a look to see the wattage mark.
many thanks for the replys
Post #120461 1st Feb 2012 8:57pm
tolley
[quote="K9F"]The wiring doesn't look 'too clever' on the lamp. Pop the filament/bulb/lamp out and somewhere there should be a wattage and voltage mark. If you have/have access to an insulation tester test the lamp wiring out with the filament/bulb/lamp removed.
took the bulb out but no wattage mark just what i mentioned before on it.
works great off a spare battery
Post #121471 5th Feb 2012 12:31pm
tolley
used a meter and got 6amps
Post #121795 6th Feb 2012 2:00pm
ZeDefender
Bingo - you're home and dry (unless you're away from home and...)
Thumbs Up Tell someone you love them today because life is short.
Post #121806 6th Feb 2012 2:43pm
