Home > Maintenance & Modifications > Heated mirror from heated screen
Page 2 of 3 <123>
ZeDefender
WarPig wrote:
Thanks, where did you buy the mirrors from?
I got mine from German eBay:
http://www.ebay.de/itm/beheizbarer-Aussens...1e6a19125d
but this seems similar (but more expensive)
http://www.ebay.co.uk/itm/Land-Rover-Defen...4ab13ec46c
must be some other UK suppliers I suppose
Photos tomorrow (but only of the finished product, I'm afraid) Tell someone you love them today because life is short.
Post #117875 23rd Jan 2012 7:10pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Post #117896 23rd Jan 2012 7:41pm
ZeDefender
pouf wrote:
here is an installation
http://la7dja.org/defender/mirror-heating/
I saw that before and it almost frightened me off even trying - seems like serious overkill Shocked
Doesn't seem to bring any advantage over just drilling one hole through the plastic and one in the frame Rolling Eyes
Also, I don't reckon that cable's chances, bent around and up against all that sharp metal... Tell someone you love them today because life is short.
Post #117903 23rd Jan 2012 7:48pm
WarPig
Thanks. Im interested in seeing photos of where you've drilled you hole, Ive been meaning to get a set of heated mirrors for ages.
Post #117905 23rd Jan 2012 7:52pm
pouf
i agree with you.But this looks professional Wink www.newfoundland.gr
Post #117918 23rd Jan 2012 8:25pm
BigRuss
bpman wrote:
BigRuss wrote:
Right I fitted a heated wing mirror kit over Christmas but several attempts to get it working have all failed Big Cry
I did have one working and found I has a loose wire so connected it and just caused the working pad to stop Big Cry
did you put the mirrors in upside down ?
No Russell
2011MY 110 XS USW Black
Post #117925 23rd Jan 2012 8:41pm
ZeDefender
As promised:
This is the position where the cable sheath goes in:
and from the inside you can see the sheath going through. Sorry I can't remove the door seal as I've..."sealed" it with Sikaflex (but you can easily see inside where the recess is deepest):
and finally where I fixed earth (the alloy is much thicker here):
I deliberately kept it "low tech" to avoid problems of wear and tear. Using this method, there is no kinking or chafing of the cable or any movement of the sheath outside at all when the door is opened or closed. Everything (glue, wire etc.) will be painted black in a few hours and, if I say it myself, the finish will certainly be in keeping with general LR build "quality" Laughing
Incidentally, the polyurethane glue is from Bison:
http://www.bison.net/en/products/647-2-com...-bisonite/
Bloody wonderful stuff - IMHO the best there is :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #118026 24th Jan 2012 8:46am
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Ive done this on my Truck, your more than welcome to come and have a look. Ive gone just under the hinge, bit more better looking than a grommet on the bulkhead, I also have a large 6mm drill to drill the bracket with to feed a cable through, although this took ages and was well tight!
PM me if you want a look.
Post #118029 24th Jan 2012 8:55am
ZeDefender
Tight is always good Whistle Tell someone you love them today because life is short.
Post #118034 24th Jan 2012 9:01am
AtleCM
Norway 2005 Defender 110 Td5 SW Java Black
Here is a kit for you guys living in UK if you don't want to replace the entire mirror.
Why don't people ship internationally? Crying or Very sad Atle CM
Norway
Def 110, S2a 88, S3 109, S2b FC
Post #118062 24th Jan 2012 10:47am
Xcelsius
I would probably order the Mudstuff elements for an extra pound over those. The Mudstuff isn't a printed circuit so there's less chance of an open trace rendering the element dead. Plus it looks like the Mudstuff ones would be able to heat more surface area like it says on their web page.
http://www.mudstuff.co.uk/Defender_Heated_Mirror_Elements.shtml
Post #118075 24th Jan 2012 11:49am
AtleCM
Thanks Xcelsius, hadn't seen those. Atle CM
Norway
Post #118078 24th Jan 2012 12:15pm
dgardel
Italy
PM sent Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #118079 24th Jan 2012 12:21pm
Paul_1978
A guide to doing the job....
Post #118080 24th Jan 2012 12:36pm
ZeDefender
That was the "frightening" one I saw - might look pretty on the surface but I didn't fancy the bent, trapped, chafing cable...
Probably not as bad as it looks from the photos though Thumbs Up Tell someone you love them today because life is short.
Post #118109 24th Jan 2012 2:00pm
Page 2 of 3 <123>
