Home > Maintenance & Modifications > Heated mirror from heated screen
Page 1 of 3 123>
ZeDefender
Morning all Smile
It's minus 12 outside this morning and I've changed my mind... I really would like a heated wing mirror!
As I have a long large purple wire easily accessible for the heated windscreen, can anyone give a reason why I shouldn't take a spur off it and use it for the mirror too? Using the same heater switch would be perfect. The screen uses a 30A fuse and the mirror I'm looking at is rated 15A max. Guess I could uprate the fuse a bit if neccesary... Whistle
Otherwise I probably won't bother (lazy Dog)
Matt
p.s. yes, I've searched (...a bit) Rolling Eyes
Have a terrific day all Thumbs Up Tell someone you love them today because life is short.
Post #115834 16th Jan 2012 8:24am
Thats how mine are done
The main and only issue is the timer on the screen as there are times when I need the mirrors on a bit longer not a train smash as they say
Post #115844 16th Jan 2012 9:01am
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
sorry to jump on your tread,is it much of a job to fit a heated screen and mirrors to td5 which has none Big Cry
thanks
Post #115861 16th Jan 2012 10:11am
ZeDefender
Great, thanks Thumbs Up
Do you stick with the 30A fuse? Tell someone you love them today because life is short.
Post #115862 16th Jan 2012 10:17am
Yep no issues at all Thumbs Up
Post #115863 16th Jan 2012 10:19am
A little o/t but related to this question:- I am planning to fit a heated screen (plus probably heated mirrors) and was also thinking of connecting theme to the same switch (I can't use the HRW circuit since I have already used that for something else).
With the standard heated screen wiring, I know that there is a timer to switch the element off after a certain period, but can it also be switched off manually before the timeout, by means of a second switch activation? or is it always on until the timer times out?
Thanks.
Post #115869 16th Jan 2012 10:43am
Yes, by pressing the button again. Mind you, the timer is only about 10 minutes, IIRC. Darren
Post #115870 16th Jan 2012 10:50am
ZeDefender
Update - heated mirror is now fitted and works a treat Thumbs Up
Gets pretty warm very quickly though - hope it lasts Whistle
Matt Tell someone you love them today because life is short.
Post #117771 23rd Jan 2012 2:28pm
BigRuss
Right I fitted a heated wing mirror kit over Christmas but several attempts to get it working have all failed Big Cry
I did have one working and found I has a loose wire so connected it and just caused the working pad to stop Big Cry Russell
2011MY 110 XS USW Black
Post #117773 23rd Jan 2012 2:51pm
WarPig
As well as buying the heated mirror elements, am I right in thinking you can also buy heated mirrors as a complete unit?
Post #117786 23rd Jan 2012 3:49pm
dgardel
Italy
Matt
Where you routing the cable? photos?? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #117787 23rd Jan 2012 4:06pm
ZeDefender
I bought a complete mirror unit (not the bracket) and there is a cable (about 3' long) sticking out of it with 2 wires. Just mount the thing on the bracket ball. Whole unit was about 30 quid.
To route the cable, I drilled a hole through to the inside, just above where the door hinge fixes to the frame. There is just enough room here (you can see it's a bit "deeper" on the inside where the door seal bends). I angled the hole slightly upwards to encourage water to come out instead of in. The frame has two skins, so to prevent chafing, I made a sheath out of a bigger piece of rubber cable to pass through the frame (slanting slightly down) and sticking out a bit both sides. Everything was glued in place with polyurethane glue and sealed up with Sikaflex (brilliant stuff Thumbs Up )
As I have a heated front windscreen, the rest was easy. I just soldered the brown wire to the windscreen heater connector and drilled a small hole just above the top "fake hinge" bolt and used a self-tapping screw to fix the blue wire to earth. The mirror just works exactly the same as the windscreen Thumbs Up
Photos tomorrow if anyone is still awake...
p.s. Still trying to convince the wife to go back to Caorle this year Wink Tell someone you love them today because life is short.
Post #117849 23rd Jan 2012 6:26pm
WarPig
Thanks, where did you buy the mirrors from?
Photos would be useful for me please Thumbs Up
Post #117858 23rd Jan 2012 6:42pm
dgardel
Italy
<thank you Ze, please take a photo " I drilled a hole through to the inside, just above where the door hinge fixes to the frame"
Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #117860 23rd Jan 2012 6:48pm
did you put the mirrors in upside down ?
Post #117869 23rd Jan 2012 6:59pm
Page 1 of 3 123>
