Home > Technical > Safari Snorkel air filter question!
Zagato
I am taking my 110 for it's first service tomorrow and was wondering about the air filter! I fitted a Safari Snorkel but I'm pretty sure I left the air filter in place Shocked Should I have done that? How can it be replaced if the snorkel is permanently covering the wing hole. I've thrown the instructions away so don't know if it should still be in place or not!
It's this one http://www.safarisnorkel.com/snorkel/ss581hf/ss581hf.htm
Post #115598 15th Jan 2012 4:51pm
TJ101
The air filter box is at the front of the car,, the RAI at the rear, both connected with pipework,,
You should not have touched the air box filter lid,, They can change the filter (if they even open the box !!???? ) without touching the RAI California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #115599 15th Jan 2012 5:04pm
Zagato
Thanks Tim Thumbs Up
Post #115600 15th Jan 2012 5:05pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I thought it was April 1st when i read that Rolling with laughter
Post #115621 15th Jan 2012 5:49pm
TJ101
I did think twice Surprised But then saw it was Zag, so must be genuine California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #115631 15th Jan 2012 5:58pm
Zagato
Very Happy Thud
This is the wing air filter of course Whistle How do you change the air filter on the wing from inside?
Post #115633 15th Jan 2012 5:58pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Be nice matt, in fairness zags probably polished it so much its turned to dust and disappeared Rolling with laughter 2004 TD5 Defender 90 xs station wagon
Post #115634 15th Jan 2012 5:59pm
Zagato
Re: Safari Snorkel air filter question!
I'm talking about the wing air filter, do pay attention at the back! How do you replace it from inside or should I have taken the filter out before fitting the Snorkel? Anyone know or got fitting instructions! Ta.
Post #115644 15th Jan 2012 6:13pm
Zag - did you remember to remove all the packaging from inside the RAI - bubble wrap etc before you fitted it Shocked
Post #115652 15th Jan 2012 6:20pm
Zagato
I have a nasty feeling I should have removed the filter before fitting the snorkel Shocked Can't find any instructions on the web, old Def2 links not working!
Post #115661 15th Jan 2012 6:26pm
*delete*
Post #115666 15th Jan 2012 6:35pm
Zagato
Anyone got fitting instructions or knows would be very helpful, have Googled 8 pages and no instructions Sad
Coming to the conclusion I should have taken it out, Censored ! Evil or Very Mad
Post #115669 15th Jan 2012 6:39pm
robpenrose
Has the Puma got more than one air filter then? Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #115677 15th Jan 2012 6:55pm
Zagato
Yes there is a filter the same shape as the side wing hole, I don't think it should be there with the Snorkel on as I can't see any easy way of replacing it from inside the wing. Unless someone who knows otherwise I think I could be having fun and games getting it back out again i.e. base of Snorkel will need unscrewing or more likely the whole snorkel will need to come off altogether to get it out Shocked Shocked Shocked Shocked If I can't get at it from inside which I don't think I can Big Cry
Post #115685 15th Jan 2012 7:04pm
bob neville
No filter behind the wing plate on mine (2009 110).
Just frozon my doo dahs off going out to the garage to double check in my box of 'bits removed' and just the plastic plate.
Of course land Rover may have forgotten to fit it Rolling with laughter
All the dealer does at service time is replace the filter in the air box - if they can be bothered Thumbs Up
2013 Defender 90 CSW - sold
Post #115689 15th Jan 2012 7:11pm
