Home > Maintenance & Modifications > Gearbox and T-case Oil Level. |
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 |
Hi!
Someone knows where is the "level check" or the "level bujon?!?!?!?!?" (I don't know the right term in english) of the new 6 speed gearbox, and of the T-case, of the new Defender?? Thanks a lot!!! Regards |
3rd Jun 2009 1:38pm |
Yeah!
The T-case fill hole I'd already found, but the gearbox ain't. regards |
4th Jun 2009 1:43pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5051 |
Acording to the workshop manual it is Mike
4th Jun 2009 3:38pm |
Hi mse
Lets see if I understand: You are saying that there are only one hole for fill/level for the gearbox and T-case, and this hole is the one located in the T-case? If it's true, the gearbox and T-case have comunication, and use the same oil!?!?!? regards |
4th Jun 2009 8:11pm |
No there is a fill and empty plugs - and you fill to the fill plug Mike |
4th Jun 2009 9:10pm |
I think you don't understand.
Let me try to explain (remember i'm from brazil, maybe my english are poor!!) hehe I know that there is one for fill (thats where you check the level) and one for empty. My question is: The hole for fill the gearbox and the T-case is the same? Or Are just one hole for fill and check level oil for gearbox and T-case? thaks for the patience! |
4th Jun 2009 11:44pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2443 |
Same question. I`ve not found it. MC doesn`t show it at all. Puma 110" SW
5th Jun 2009 5:02am |
I understand - there are a fill and drain plug for both boxes.
Remember though you only have to change the gearbox at 100 000miles Mike |
6th Jun 2009 11:54am |
100000 miles?!?!?!?!
Here in Brazil we change the diffs in 12500 miles (20000 km) And Gearbox and T-case in 25000 miles (40000 km) (same oil for both) and about the drain plug you refer that there are ONE fill and drain plug for both boxes????? when you said: "I understand - there are a fill and drain plug for both boxes." And this only ONE drain plug for both boxes is located in tht T-case???? Sorry, but it stay confuse for me |
6th Jun 2009 12:13pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6632 |
The gearbox and the transfer box have their own fill and drain plugs.
I don't know where the Puma gearbox plugs are, but they are separate from the transfer box ones. So the transfer box has fill and drain plugs, and the gearbox has fill and drain plugs - the boxes do not share oil. |
6th Jun 2009 12:17pm |
Exactly - What ive been saying.
And yes the service interval for the new transmission is significantly greater than those before it. Mike |
6th Jun 2009 4:51pm |
Just trying to clear up some vagueness in the English language - the subtlety of "both" meaning "each"
6th Jun 2009 5:03pm |
Mike |
6th Jun 2009 5:05pm |
Thank a lot guys!
now everything clear! And, thanks for the tip Martin!!! When someone discover where is the puma gearbox plugs, please post! regards! |
7th Jun 2009 1:02am |
