Home > Maintenance & Modifications > Gearbox and T-case Oil Level.
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Hi!
Someone knows where is the "level check" or the "level bujon?!?!?!?!?" (I don't know the right term in english) of the new 6 speed gearbox, and of the T-case, of the new Defender??
Thanks a lot!!!
Regards
Post #11502 3rd Jun 2009 1:38pm
I've not looked at the 6 speed box, but the transfer box is filled to the point that oil comes out of the filler hole (about half way up just behind the handbrake drum)
I'd imagine that the main gearbox is the same too, most are.
Post #11517 4th Jun 2009 9:07am
Gabriel Boff
Yeah!
The T-case fill hole I'd already found, but the gearbox ain't.
regards
Post #11532 4th Jun 2009 1:43pm
mse
Acording to the workshop manual it is Mike
Post #11539 4th Jun 2009 3:38pm
Gabriel Boff
Hi mse
Lets see if I understand:
You are saying that there are only one hole for fill/level for the gearbox and T-case, and this hole is the one located in the T-case?
If it's true, the gearbox and T-case have comunication, and use the same oil!?!?!?
regards
Post #11564 4th Jun 2009 8:11pm
mse
Gabriel Boff wrote:
Hi mse
regards
No
there is a fill and empty plugs - and you fill to the fill plug Mike
Post #11565 4th Jun 2009 9:10pm
Gabriel Boff
I think you don't understand.
Let me try to explain (remember i'm from brazil, maybe my english are poor!!) hehe
I know that there is one for fill (thats where you check the level) and one for empty.
My question is:
The hole for fill the gearbox and the T-case is the same?
Or
Are just one hole for fill and check level oil for gearbox and T-case?
thaks for the patience!
Post #11566 4th Jun 2009 11:44pm
MK
Same question. I`ve not found it. MC doesn`t show it at all. Puma 110" SW
Post #11569 5th Jun 2009 5:02am
mse
I understand - there are a fill and drain plug for both boxes.
Remember though you only have to change the gearbox at 100 000miles Mike
Post #11645 6th Jun 2009 11:54am
Gabriel Boff
100000 miles?!?!?!?!
Here in Brazil we change the diffs in 12500 miles (20000 km)
And Gearbox and T-case in 25000 miles (40000 km) (same oil for both)
and about the drain plug you refer that there are ONE fill and drain plug for both boxes????? when you said: "I understand - there are a fill and drain plug for both boxes."
And this only ONE drain plug for both boxes is located in tht T-case????
Sorry, but it stay confuse for me
Post #11646 6th Jun 2009 12:13pm
Martin
Site Admin
The gearbox and the transfer box have their own fill and drain plugs.
I don't know where the Puma gearbox plugs are, but they are separate from the transfer box ones.
So the transfer box has fill and drain plugs, and the gearbox has fill and drain plugs - the boxes do not share oil.
Post #11647 6th Jun 2009 12:17pm
mse
Exactly - What ive been saying.
And yes the service interval for the new transmission is significantly greater than those before it. Mike
Post #11658 6th Jun 2009 4:51pm
Martin
Site Admin
Just trying to clear up some vagueness in the English language - the subtlety of "both" meaning "each" Wink
Post #11660 6th Jun 2009 5:03pm
mse
Laughing Mike
Post #11662 6th Jun 2009 5:05pm
Gabriel Boff
Thank a lot guys!
now everything clear!
And, thanks for the tip Martin!!! Laughing
When someone discover where is the puma gearbox plugs, please post! Wink
regards!
Post #11671 7th Jun 2009 1:02am
