![]() | Home > Technical > transfer box q's |
westfield106 Member Since: 29 Dec 2009 Location: leeds Posts: 58 ![]() ![]() |
hi
are the transfer boxes the same in the tdci as the td5 ie lt230 1.4 ratio ??? cheers john |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 ![]() ![]() |
Think the Tdci uses the 1.2 trans box like the disco
Andy |
just to be clear, defender td5's are 1.4, defender 2.4/tdci's are 1.2 (discovery td5's are 1.2) |
thanks for the replies
![]() is it possible to fit a transfer box from a 300tdi disco then -- provided its fitted with difflock ??? as they are lt230 1.2 ratio ??? |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
I put a disco transfer box into mine 2 weeks ago and it had turned out great.
Mine was from a 300tdi, going into a TD5 110. Few things to note - Difflock switch is different and needed re wiring Hi Low switch won't fit Speedo over reads - I will look into changing the plastic cog to fix that at some point. Had to remove the harmonic dampner. All told, it was an easy job taking 3 hours to complete. 2002 Defender 110 DC |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
why? the tdci has CDL aswell. |
thought some of the discos didnt have difflock lever etc ??? fitted with cdl but no levers to activate it ?? mine is noisy when you engage cdl even when at crawling pace -high or low box --- ideas welcome but presume fault with cdl so looking at replacing transferbox and wondering which ones are compatible |
later td5 discos didn't have CDL. but why do you want to change yout tdci TB for an older ones??? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 ![]() ![]() ![]() |
According to his icon, the OP has a Td5, not Puma.
We've not been told why the original question was asked, that bit of info is missing, hence the confusion I think! ![]() ![]() |
well he says he's just bought a puma! |
ok |
CDL was deleted for some of the disco 2 period, so a 300dti disco box will be fine. 2002 Defender 110 DC
icon needs updating as of today ![]() avatar is of my 200 tdi offroader ![]() bought an 08 tdci with 20k mls on it owner said difflock had never been used !!! but if you select difflock then it makes a loud rumbling noise from transferbox area ??? drives ok without difflock engaged. just driven it 70ish miles home without fault ![]() ![]() |
