Home > Technical > transfer box q's |
westfield106 Member Since: 29 Dec 2009 Location: leeds Posts: 58 |
hi
are the transfer boxes the same in the tdci as the td5 ie lt230 1.4 ratio ??? cheers john |
10th Jan 2012 4:48pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 |
Think the Tdci uses the 1.2 trans box like the disco
Andy |
10th Jan 2012 5:19pm |
just to be clear, defender td5's are 1.4, defender 2.4/tdci's are 1.2 (discovery td5's are 1.2) |
13th Jan 2012 10:39pm |
thanks for the replies
is it possible to fit a transfer box from a 300tdi disco then -- provided its fitted with difflock ??? as they are lt230 1.2 ratio ??? |
14th Jan 2012 8:35pm |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
I put a disco transfer box into mine 2 weeks ago and it had turned out great.
Mine was from a 300tdi, going into a TD5 110. Few things to note - Difflock switch is different and needed re wiring Hi Low switch won't fit Speedo over reads - I will look into changing the plastic cog to fix that at some point. Had to remove the harmonic dampner. All told, it was an easy job taking 3 hours to complete. 2002 Defender 110 DC |
14th Jan 2012 9:05pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
why? the tdci has CDL aswell. |
thought some of the discos didnt have difflock lever etc ??? fitted with cdl but no levers to activate it ?? mine is noisy when you engage cdl even when at crawling pace -high or low box --- ideas welcome but presume fault with cdl so looking at replacing transferbox and wondering which ones are compatible |
14th Jan 2012 9:12pm |
later td5 discos didn't have CDL. but why do you want to change yout tdci TB for an older ones??? |
14th Jan 2012 9:17pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
According to his icon, the OP has a Td5, not Puma.
We've not been told why the original question was asked, that bit of info is missing, hence the confusion I think! 1988 90 Td5 NAS soft top 2015 D90 XS SW |
14th Jan 2012 9:19pm |
well he says he's just bought a puma! |
14th Jan 2012 9:20pm |
OK, but you didn't need to repeat what I just said 1988 90 Td5 NAS soft top
2015 D90 XS SW |
14th Jan 2012 9:21pm |
ok |
14th Jan 2012 9:26pm |
CDL was deleted for some of the disco 2 period, so a 300dti disco box will be fine. 2002 Defender 110 DC
14th Jan 2012 9:30pm |
icon needs updating as of today avatar is of my 200 tdi offroader bought an 08 tdci with 20k mls on it owner said difflock had never been used !!! but if you select difflock then it makes a loud rumbling noise from transferbox area ??? drives ok without difflock engaged. just driven it 70ish miles home without fault poss have access to 300tdi transferbox to try before i dive in and order a new transferbox from ashcrofts so just wanting to clarify compatibility ???? |
14th Jan 2012 9:31pm |
