Home > Puma (Tdci) > Are Puma windscreens glued?
Page 1 of 4 1234>
ZeDefender
I'm having a discussion with Carglass (Autoglass in the UK) about the cost to professionally (i.e. not LR) re-fit/seal my windscreen. It's Censored down with rain all the time here so I can't seal it myself... and my foot is soaking... so I'm just looking at alternatives.
Whether the screen is glued in or not determines the cost and who has to pay if it breaks...
MY2011 - any info?
Matt Tell someone you love them today because life is short.
Post #114131 10th Jan 2012 8:46pm
bob neville
No Thumbs Up
Old fashioned glass in rubber seal, no glue anywhere.
2013 Defender 90 CSW - sold
Post #114132 10th Jan 2012 8:49pm
ZeDefender
bob neville wrote:
No Thumbs Up
Bob
Brilliant - but would be better if it didn't leak Rolling Eyes
Cheers Thumbs Up
Matt
p.s. do you happen to know how much a new heated screen costs (approx)? Tell someone you love them today because life is short.
Post #114134 10th Jan 2012 8:51pm
wslr
The part number is LR009820 which is 'WITH CLEAR GLASS - COMPLETE, WITH HEATED WINDSCREEN' and is GBP 272.89 + VAT
Should be paying no more than GBP50+VAT for fitting.
Post #114137 10th Jan 2012 9:02pm
Happyoldgit
Are you sure it's the screen? Have you looked at the bulkhead to frame seal, bracket seals etc too? Steve.
http://forums.lr4x4.com
Post #114140 10th Jan 2012 9:07pm
ZeDefender
I can see the water dribbling in just under the windscreen rubber when it's raining, so some is definitely coming in there. I can't tell yet if any is getting through the bulkhead seal - it is wet along the top but that's probably just from under the windscreen rubber above. If the bulkhead seal is leaking, I'm hoping Todger's creeping crack sealant will sort it out (if I can get things dry enough in the work garage...
Thanks for the heads up Thumbs Up Tell someone you love them today because life is short.
Post #114146 10th Jan 2012 9:34pm
if you can get them to use a new rubber and Zag can recommend some sealant ... not sure of your situation... was this a planned change or is it an emergency ?
I had my td5 one changed, the man broke 2 trying to fit a new one Sad
Post #114147 10th Jan 2012 9:35pm
ZeDefender
Many thanks Thumbs Up Tell someone you love them today because life is short.
Post #114148 10th Jan 2012 9:38pm
ZeDefender
not exactly an "emergency" yet but its getting worse in the rain and will be much worse when the snow/slush comes and sits on the guttering Sad Tell someone you love them today because life is short.
Post #114150 10th Jan 2012 9:42pm
maybe for the time being, run some grease around the edges to keep the water out until it dries up a little and you can tackle the job in the dry, take your time and get all the right sealants ? (sorry not telling you what to do, just that's what i'd do) Thumbs Up
Post #114153 10th Jan 2012 9:50pm
ZeDefender
As I said, I'm looking at all possibilities over the next few days and that's a good one - it will also tell me if the bulkhead seal is leaking too Thumbs Up
Actually, if the bulkhead seal is leaking too, keeping it greased might also be a fix for now - unless the grease attacks the foam rubber Confused
Also just thought that if Carglass break the screen, I could claim it happened on the road and get my insurance to pay for it Twisted Evil
Post #114160 10th Jan 2012 10:08pm
Happyoldgit
Personally I'd be wary of using grease anywhere near where you will want to be permanently sealing up at a later stage, getting rid of the grease so that the sealant can take effect / bond is likely to be a PITA. Steve.
Post #114222 11th Jan 2012 9:53am
Ten years in the windscreen game, we used this...
http://www.ebay.co.uk/itm/ARBOMAST-WINDSCR..._518wt_698
Post #114227 11th Jan 2012 10:10am
Zagato
Thumbs Up Exactly what you want (Same as the stuff from Frosts.co.uk) because as it says...
"ALWAYS FLEXIBLE ALTHOUGH FORMS A SINK ON THE SURFACE. THIS SEALANT IS USED BETWEEN THE GLASS AND RUBBER AND ALSO THE RUBBER AND BODYWORK TO PREVENT OR TO STOP LEAKAGE"
No need to take the rubber out, just seal it and as MOG says avoid grease Thumbs Up
Post #114232 11th Jan 2012 10:22am
ZeDefender
Thanks all - will only use grease in dire emergencies Thumbs Up
I would have to order Arbomast from UK so I'll check out what e.g. Carglass use here (probably similar).
Last questions:
1) If I do get Carglass to do the whole job (they now tell me they can for around 50 quid), do you think I should get a new rubber seal? This one is only 10 months old and I can only find cheapo copies (30 quid) on the German net?
2) If the bulkhead-frame seal is leaking, I have loads of butyl tape I can use to make a permanent flexible barrier covering the foam rubber seal from the outside - is there any reason the seal has to be open to the air?
Many thanks
Post #114266 11th Jan 2012 12:16pm
Page 1 of 4 1234>
