Home > Puma (Tdci) > Are Puma windscreens glued?
Page 2 of 4 <1234>
Happyoldgit
Yup, that's what I've used in the past too Thumbs Up Steve.
http://forums.lr4x4.com
Post #114267 11th Jan 2012 12:17pm
Happyoldgit
ZeDefender wrote:
Zagato wrote:
No need to take the rubber out, just seal it and as MOG says avoid grease Thumbs Up
Thanks all - will only use grease in dire emergencies Thumbs Up
I would have to order Arbomast from UK so I'll check out what e.g. Carglass use here (probably similar).
Last questions:
1) If I do get Carglass to do the whole job (they now tell me they can for around 50 quid), do you think I should get a new rubber seal? This one is only 10 months old and I can only find cheapo copies (30 quid) on the German net?
2) If the bulkhead-frame seal is leaking, I have loads of butyl tape I can use to make a permanent flexible barrier covering the foam rubber seal from the outside - is there any reason the seal has to be open to the air?
Many thanks
Matt
Honestly Matt don't use grease!
On older, out of warranty Defenders with non opening screens I've often resorted to a bead of sealant over the bulkhead to screen frame seal, it works well Thumbs Up Steve.
Post #114270 11th Jan 2012 12:24pm
ZeDefender
Okay - I promise - no grease Laughing Tell someone you love them today because life is short.
Post #114277 11th Jan 2012 12:51pm
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Zag/ all
Mines not leaking, would you still advise me to seal it anyway, or could this cause problems rather than eliminate them?
Post #114284 11th Jan 2012 1:37pm
If it ain't broke......
Post #114286 11th Jan 2012 1:45pm
xatzhs
On a Defender.... Probably just means you haven't noticed it's broken yet Thumbs Up
Post #114287 11th Jan 2012 1:47pm
ZeDefender
...it's not a Defender Laughing Tell someone you love them today because life is short.
Post #114288 11th Jan 2012 1:48pm
AndrewS
This is what you need Whistle
http://www.sika.com.au/cmc/Datasheets/tds/SikaSwellS_tds.pdf 130's have feeling's as well you know Smile
Post #114289 11th Jan 2012 1:49pm
ZeDefender
Censored it - you got there first Wink
Looks good too Thumbs Up
Blimey - perhaps we should have a window sealant database Shocked Tell someone you love them today because life is short.
Post #114290 11th Jan 2012 1:49pm
xatzhs
Definitely catchier than mine though! Very Happy
Post #114292 11th Jan 2012 1:53pm
ZeDefender
To be honest I'm just Censored Censored Censored off that the Censored at Land Rover are too incapable to do something so Censored easy as fit a bloody windscreen properly Evil or Very Mad Tell someone you love them today because life is short.
Post #114294 11th Jan 2012 1:56pm
Happyoldgit
The seal is just a length of closed cell foam which IIRC has a bit of self adhesive tape either side but in the past I've just used a length from a roll without the sticky tape which can be bought from extrusion / trim supplies. TBH the older they are the more likely they are to break down and act like a sponge so I can't see the harm in running a neat bead of something over the top and around the sides - just as long as it's dry underneath. Steve.
Post #114295 11th Jan 2012 1:57pm
ZeDefender
Thanks - so for now I'll cover it in butyl (the blue-tacky type) - I love the stuff Thumbs Up
We had an old caravan which sprang a leak in Croatia. All I had to do was scrape off some excess (15 year old!) butyl underneath one corner, work it a bit and stick it over the crack. It was still there a year later when we sold it Wink Tell someone you love them today because life is short.
Post #114301 11th Jan 2012 2:09pm
Zagato
Dean Watson wrote:
Zag/ all
Yes seal it, you don't want water sitting under your rubber rotting the metal away where any paint has been scraped off whilst fitting the window or into any of the frame joins! My 5 year old TD5 frame had holes in it from this Shocked . It also stops leaks, hell you just don't fit a window without sealing it Rolling Eyes You don't take the window out just run a line of sealant under the window rubber - glass to rubber, body to rubber, this IS how old style windows where fitted. The right stuff to use has already been explained by 3 people, one in the trade. It's messy but will take no longer than 1/2 an hour for the front window for instance or better still get a local window fitter to do it all for you for £100 ish . They do it sooo quickly Wink
It's all in the corrosion guide Big Cry http://www.defender2.net/forum/topic10467.html
Look at the Puma water ingress manual, may have to Google it, says "sealing windows, glass to rubber, rubber to body" etc etc! It's all in there, it's not hard to do, only takes a day to do it all Thud
Post #114311 11th Jan 2012 2:23pm
ZeDefender
I seem to have downloaded a copy where the windscreen wasn't mentioned Confused
Must check again Rolling Eyes
I agree with everything you say but the OCD in me still wonders if taking it all to pieces and sealing everything on assembly (if possible) might be Whistle better Whistle
However, I'm slowly being convinced to do it your way - and it's stopped raining for a while Thumbs Up
Go on, shout at me Embarassed
p.s. plus I'm rubbish and messy at any kind of sealing/painting - you would Censored yourself laughing if you saw our shower tray Laughing Tell someone you love them today because life is short.
Post #114325 11th Jan 2012 3:25pm
Page 2 of 4 <1234>
