Home > Puma (Tdci) > Door stay adjustment |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4731 |
What is the easiest way to adjust the hidden bolt behind the trim for the door stay. I am currently using an 8mm open ended spanner. It is awkward as I can only get a fraction of a turn at a time. I do not want to have to remove the trim. No doubt someone out there has a better way. 1982 88" 2.25 diesel
24th May 2009 9:47pm |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 |
Adjusting the rear door requires the lining to be removed:
http://www.aulro.com/afvb/90-110-130-defen...-open.html The front passenger doors are easier to do...I did it a few weeks ago and have forgotten how I did it I'll get back to you. Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
26th May 2009 10:10am |
Thanks I was hoping someone had a way of adjusting these bolts without removing the door trim. 1982 88" 2.25 diesel
30th May 2009 7:54pm |
On the front doors I used a 1/4" drive 8mm socket that fitted between seal and the trim. Mahn
31st May 2009 12:39am |
Thank you- motor factors here I come!!!!! 1982 88" 2.25 diesel
1st Jun 2009 8:18am |
Pob Member Since: 23 Jan 2009 Location: Midlands Posts: 119 |
Did my back door thanks to this post - thankyou Very easy - took me just 5 mins to remove the torx screws on the door handle, remove door card, adjust door and refit.
I wish I knew it was this easy before Had last 2 Defenders with rear doors that kept swinging shut - it used to do my nut in |
1st Jun 2009 9:54am |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
Like Pob have also done mine - very easy to do - it's amazing what you put up with when you don't know any better!
1st Jun 2009 8:18pm |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 |
Maybe I missed something, but what is there to adjust? mine were just loose. From the factory! No suprise there then.
2nd Jun 2009 10:59am |
The position of the plate makes the metal rod press against the door stay more or less - depending what position it's in.
2nd Jun 2009 3:11pm |
Thanks Pob, I'll have another look.
2nd Jun 2009 3:45pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
That's the beauty of Land Rovers. If it don't work then you can probably either fix it, replace it or invent something else to go in its place. I'm tempted to fashion something that I can use to fix the rear door open. If I park on any kind of side slope it is impossible to unload. A simple latching bracket should do. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
2nd Jun 2009 7:51pm |
Just what I did untill I tightened up the rear door stay spring, except I used a piece of wood wedged between the lower door edge rebate and the ground.
3rd Jun 2009 5:53am |
One of the guys on aulro.com. has used a gas strut mounted to the top of the door to solve his problem. Mahn
3rd Jun 2009 5:55am |
I thought about that but I assumed it would make the door harder to open or shut (again, with the weight of it + wheel it is already hard enough if you're going against gravity). I just assumed the gas strut would be effective at dampening the motion. I don't really want that - I just want to be able to lock it open so I am free to load/unload. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
3rd Jun 2009 3:53pm |
