Home > Puma (Tdci) > Door stay adjustment
spudfan
Ireland
What is the easiest way to adjust the hidden bolt behind the trim for the door stay. I am currently using an 8mm open ended spanner. It is awkward as I can only get a fraction of a turn at a time. I do not want to have to remove the trim. No doubt someone out there has a better way. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #11265 24th May 2009 9:47pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
I'm not sure what you want to "adjust", or even if there is anthing to adjust. But if it's any use, I found on my new 90 that the doors (yes, all three) wouldn't stay open. When I looked, I found that all three tension spring clamp bolts were loose. The front ones were relatively easy to tighten up with a small socket, but I had to remove the trim to get to the one on the back door. Hope that helps.
Bosun.
Post #11286 26th May 2009 6:38am
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
Adjusting the rear door requires the lining to be removed:
http://www.aulro.com/afvb/90-110-130-defen...-open.html
The front passenger doors are easier to do...I did it a few weeks ago and have forgotten how I did it Rolling Eyes
I'll get back to you. Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #11289 26th May 2009 10:10am
spudfan
Ireland
Thanks I was hoping someone had a way of adjusting these bolts without removing the door trim. 1982 88" 2.25 diesel
Post #11405 30th May 2009 7:54pm
one_iota
On the front doors I used a 1/4" drive 8mm socket that fitted between seal and the trim. Mahn
'08 Defender 110
www.aulro.com
Post #11406 31st May 2009 12:39am
spudfan
Ireland
Thank you- motor factors here I come!!!!! 1982 88" 2.25 diesel
Post #11424 1st Jun 2009 8:18am
Pob
United Kingdom 2008 Defender 110 Puma 2.4 HT Rimini Red
Did my back door thanks to this post - thankyou Thumbs Up Very easy - took me just 5 mins to remove the torx screws on the door handle, remove door card, adjust door and refit.
I wish I knew it was this easy before Rolling Eyes Had last 2 Defenders with rear doors that kept swinging shut - it used to do my nut in Laughing
Post #11426 1st Jun 2009 9:54am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Like Pob have also done mine - very easy to do - it's amazing what you put up with when you don't know any better!
Post #11434 1st Jun 2009 8:18pm
Bosun
Maybe I missed something, but what is there to adjust? mine were just loose. From the factory! No suprise there then.
Post #11461 2nd Jun 2009 10:59am
Pob
The position of the plate makes the metal rod press against the door stay more or less - depending what position it's in.
Post #11466 2nd Jun 2009 3:11pm
Bosun
Thanks Pob, I'll have another look.
Post #11467 2nd Jun 2009 3:45pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
That's the beauty of Land Rovers. If it don't work then you can probably either fix it, replace it or invent something else to go in its place.
I'm tempted to fashion something that I can use to fix the rear door open. If I park on any kind of side slope it is impossible to unload. A simple latching bracket should do. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #11476 2nd Jun 2009 7:51pm
Bosun
Just what I did untill I tightened up the rear door stay spring, except I used a piece of wood wedged between the lower door edge rebate and the ground.
Post #11489 3rd Jun 2009 5:53am
one_iota
One of the guys on aulro.com. has used a gas strut mounted to the top of the door to solve his problem. Mahn
'08 Defender 110
www.aulro.com
Post #11490 3rd Jun 2009 5:55am
alantd
I thought about that but I assumed it would make the door harder to open or shut (again, with the weight of it + wheel it is already hard enough if you're going against gravity). I just assumed the gas strut would be effective at dampening the motion. I don't really want that - I just want to be able to lock it open so I am free to load/unload. One that started out as a 2.4 TDCi 110 XS
Post #11503 3rd Jun 2009 3:53pm
