Home > Maintenance & Modifications > Door Seals
Page 1 of 3 123>
robpenrose
Door Seals
I am getting a lot of water in my passenger footwell after rain. I think one of the issues is that the door seal has a distorted shape from original, so think a new one is in order.
Had a look on Land Rover Parts and its basically £52 + Vat for one side. Seems fairly expensive to me.
They do an "All Makes" one which is nearer £20 + vat. Just wandering if anyone had experince in the difference in quality between the two or could recommend a good alternative to go with? I notice the weight of the genuine LR seal is nearly 0.2kg heavier according to the website.
I would like to replace both the front ones, but at over £100, it doesnt seem worth it.
If everyone says only use genuine, then i guess i will just replace the knackered one.
Any thoughts welcomed.
Rob Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #112360 5th Jan 2012 10:42am
ZeDefender
Quick question - does the floor get wet continuously or do you sometimes get a waterfall onto your feet, even when the rain has stopped? Tell someone you love them today because life is short.
Post #112378 5th Jan 2012 11:00am
robpenrose
when im driving in rain etc, i dont get anything coming in, when its left sitting and i come back to it, big puddle.
Never really noticed it dripping in, just find puddles. Another place it could be coming from is the fake hinge bit between the winscreen and bulkhead. cant remember whats its called Current:D4 HSE
Gone: BMW Z4MC
Post #112382 5th Jan 2012 11:08am
ZeDefender
Just asked 'cos I'm getting similar. There's loads of stuff on the forum about water ingress (if you haven't already, Google "Defender water ingress" and you'll find LR's official manual).
I've now packed kitchen roll into various nooks and crannies to find out where the water comes from. My suspects are:
1) windscreen rubber to frame seal (LR don't seal it!)
2) foam rubber seal under the windscreen gutter
3) "fake hinge"
4) various holes in bulkhead (engine compartment) that LR don't seem to care about sealing properly.
5) Clutch pedal seal in bulkhead (the water pours down the clutch pedal and spring is rusting)
My window seals are okay.
What I don't understand is where the water can pool up to give my "quick waterfall" down the pedal Rolling Eyes
Matt Tell someone you love them today because life is short.
Post #112386 5th Jan 2012 11:20am
robpenrose
ah so yours is on the drivers side, but mine is passenger, but i guess both LHS??
The kitchen roll is a good idea though.. Current:D4 HSE
Gone: BMW Z4MC
Post #112389 5th Jan 2012 11:25am
ZeDefender
Yup - both LHS. Yours might not have a cutout for the clutch on the LHS, so that might be a clue for me Thumbs Up
Forgot to mention, if I run out of ideas, I'm going to pack the gap under the gutter with butyl tape (leaving the foam rubber in for now) If that works I have (only) read that you can:
1) loosen the fake hinge, get someone to sit on the roof to compress the foam rubber then re-tighten the hinge
2) dig out the foam rubber and seal with Sikaflex or similar
That would really be my last resort Shocked
I am a bit reluctant to go to LR in that case as I have also read they may take the roof off and other frightening things. We shall see... Tell someone you love them today because life is short.
Post #112391 5th Jan 2012 11:28am
roadracingtog
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Just to add something to this debate. I had a mysterious puddle ( Laughing ) in the front passenger footwell of my 110 USW (Puma). I couldn't spot where it was coming from. I switched the fresh air/recirculated air slider to fresh air the other day and water dripped onto the mat when I went round a corner. I was still puzzled though of how it was getting in.
Fast forward a few days and whilst fitting my fibreglass snow cover I noticed a pool of water at the bottom of the cavity of the air intake (i.e. beneath the wing top). I discovered a rubber plug at the base of the cavity. This plug has a fluted or tapered outlet which allows water to drain away. This plug was blocked with muddy crud. I cleared it and the cavity now drains away Thumbs Up as it should. The consequence of this action and therefore my assumption is that this has cured the footwell puddle. It's never happened since.
I may be wrong but it does seem more than coincidental. We've certainly had more than enough rain for the puddle to have reappeared but since I unblocked the plug there's been no ingress of water. If this is the source then that's all well and good but I'm afraid I can't confirm it's route from the cavity to the cab. It may be worth checking though.
Post #112395 5th Jan 2012 11:41am
robpenrose
Thanks for the information. I will check that.
It might not be the seal, but its definately deformed and the door doesnt shut particularly well, so a new seal might help.
Just not sure if its worth the +£50 + Vat compared to a cheaper alternative.
Thanks Current:D4 HSE
Gone: BMW Z4MC
Post #112539 5th Jan 2012 5:59pm
Retroanaconda
Yes, definitely. Aftermarket door seals are rubbish.
Genuine is the way forward, I've just replaced both on my 90. The way I look at it, £110 for a pair of door seals every 20 years is not bad going...
Post #112551 5th Jan 2012 6:19pm
I agree, use genuine.
One thing you could try .. I used to get some water in on my td5, passenger side - it seemed to be in the curve of the door where the rubber bends, I put some grease on the rubber and that solved it .. Thumbs Up
Post #112565 5th Jan 2012 6:41pm
bob neville
Still trying to find somebody who has fitted the Nak seals. Expensive but if they stop the leaks and fit better than the OEM ones then I would fit them.
Bob
Post #112568 5th Jan 2012 6:46pm
Zagato
Usual trick is to draw a line of chalk under the suspected leak points - you can easily see where the leak crosses the chalk Thumbs Up
Post #112570 5th Jan 2012 6:47pm
pom
message user Thelargeone on the disco3 forum he is parts manager at Yeovil and does a nice forum discount, posts the parts etc.
Pom
Post #112571 5th Jan 2012 6:48pm
RRUK
I had less leaks in my 1979 Series 3! Rolling with laughter 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #112578 5th Jan 2012 6:59pm
Retroanaconda
Bob
NAK seals? Care to elaborate?
Post #112586 5th Jan 2012 7:26pm
Page 1 of 3 123>
