![]() | Home > Maintenance & Modifications > Door Seals |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
Hi Bob,
I have the Nakatanenga seals on my front doors, and whilst they definitely reduce dust ingress dramatically, and even reduce wind noise, they don't (in my experience, but I didn't have leaky doors before fitting them) have much effect on water ingress (nor, AFAIK, are they designed to). To be fair, the only leaks I had in my 110 were coming from the screen seals (both from the windscreen rubber, foam strip below windscreen and gasket behind screen 'block'. I cured all of these leaks with a good application of Captain Tolley's Creeping Crack Cure, which is superb stuff (originally designed for boats). It has very high viscosity, which helps it to 'seek out leaks/gaps;. Before you all snigger, do a Google search! I now have a perfectly dry interior in my 110......for now anyway!
![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
Thanks James
![]() Bob |
Did you remove the foam rubber strip under the windscreen first or just treat the foam rubber itself? AND how much would I need for the windscreen surround and the foam? I have a choice between 60 ml and 250 ml and postage from the UK ain't cheap ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Snowbeast17 Member Since: 20 Nov 2011 Location: Highlands Posts: 48 ![]() ![]() ![]() |
Hi guys, I still have this water leak dripping on to the brake peddle and last week thought I had worked out where it was comming in. I thought it was through the rubber foam under the windscreen. You can see about 1cm of it at the side of the dash and it was soaking wet. So I neatly siliconed it ( black) thinking this was going to fix it.
Well it didn't! So now I'm sure it's coming through the windscreen seal and running down from there. It going to the dealer to get the windscreen sealed so hopefully that will be it sorted. RRS tdv8 08 Disco 3 HSE 57 Defender 90 xs 06 All gone |
I merely squirted a small 'bead' of Captain Tolley's all along the foam strip, top and bottom, around the windscreen blocks, and also around the inner bottom corners of the windscreen rubber.
It's very runny stuff, and you only need a very small amount, as it 'finds its way' to the leaks by capillary action. If you put too much on, you end up having to wipe off the excess. It does dry clear, though. 60ml should do you. I've used only a fraction of the bottle I bought.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2720 ![]() ![]() |
My concern with this is that the instructions for this stuff say it doesn't work in wet conditions. The inside of my windscreen seal is quite wet (god-damn new seal leaking, can't believe it!), so I doubt it would work in my case. For what it's worth I have a new windscreen seal, new foam strip, new seals under the screen clamps, new door seals. Still ******* leaks! |
Actually, it doesn't say it doesn't work in wet conditions, but it does say that the area should be as dry as possible.
In my case, I did it in the height of Summer. However, what about plugging a small fan heater to an extension cable and leave it sitting on the front seat, facing the windscreen. After an hour or so, the seal should have dried out?
bmc054 Member Since: 02 Jul 2011 Location: Doncaster Posts: 32 ![]() ![]() |
I replaced the seal between screen and bulkhead but found one wasnt thick enough to stop the leak so I fitted two one on top of the other and pulled the roof down with a ratchet strap each side to compress the seals while I put the bolts back through
Hope this helps Bob |
These ![]() http://nakatanenga-tours.de/shop/article_T...DDLL-VR%26 Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Tazz Member Since: 24 Mar 2011 Location: Harrow Posts: 90 ![]() ![]() |
Well I fitted aftermarket seals from Craddocks (TD5 110) and have no complaints.
check the washer pipes for the rear window washer, water can track through the bulk head on the pipes,remove the speaker for access 2.4 90 XS
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 619 ![]() ![]() ![]() |
Well I just fitted a set of front door rubber seals from Paddocks (which are actually Britpart) and now I have to slam the doors so hard to shut them I feels like I am going to break something and the
![]() Where can I get a genuine set from? |
I've paid for "OEM" and got "the other one" from Paddocks before
![]() But shout it at them in German because life is also terrifying and confusing... |
sewin elwy Member Since: 08 Aug 2012 Location: Snowdonia Posts: 39 ![]() ![]() ![]() |
If the water is pooling in the foot well and or running down the pedel it will be getting in at the foam seal between the bulkhead and the pedel box.
Its the same as all the other foam seals and they have a very short effective life! Silkaflex is great stuff and works really well. Use it on this seal and on the seals for the screen, roof at the front and the tub. You can get a really professional finish without much effort. Leave the original seals in place as you are then only surface filling. If you need to dismantle in the future a simple shallow central cut is all that's required to release them. On areas like the tub use masking tape either side of the joint, don't over-fill and use a plastic spatula to remove the excess. then the wet finger technique to finish. It will give you a factory finish I promise! If anyone wants a look at mine and are local ( I'm just off the A55 in north wales) you're welcome! Martin. |
