Home > Td5 > Cable from battery to underseat fusebox |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
Do you have all the bits for the td5 conversion yet Al? i@m breaking a td5and have a full engine conversion for sale |
4th Jan 2012 8:15pm |
Arbman Al Member Since: 04 Jan 2012 Location: Surrey Posts: 80 |
Nearly finished now, so should be ok - thanks anyway. Apart from the cable mentioned above... 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
4th Jan 2012 8:18pm |
4th Jan 2012 8:30pm |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 286 |
Hi Arbman Al have sent you a massage with my contact number, give me a call I will help you.
Thansk Ash |
4th Jan 2012 8:53pm |
Thanks for the advice earlier Ash. Top bloke!! 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
4th Jan 2012 10:25pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 |
The cable is the main power feed to the underseat fusebox.
One end has the battery terminal, the other is a right angled lug with a hole through it, which fits into the fusebox and is screwed down. The cable also has 2 zip ties that attach to a couple of the bolt ends that poke through the underside of the top of the seatbox...the ties have a part that pushes up onto threaded bolts and secures them in place. you don't really want that cable dangling and catching something as it's +ve direct from the battery! |
5th Jan 2012 1:52pm |
Does this cable run inside the cab behind the seats, or under the cab?
Does it matter, as very tricky making 2" holes in the side of the seat box for the grommets. 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
11th Jan 2012 9:04pm |
It runs under the seatbox.
11th Jan 2012 9:10pm |
ok cheers. Any tips on cutting large holes in the side of the drivers seat box? Engine and gearbox back in now.... 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
11th Jan 2012 10:00pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17581 |
Q-Max sheet metal punch http://www.lawson-his.co.uk/scripts/produc...%20Cutters |
11th Jan 2012 10:53pm |
Hole saw? linky <-----
12th Jan 2012 7:53am |
That is what I used in the end. There was more room underneath to use a drill than I thought with the gearboxes back in 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
12th Jan 2012 7:47pm |
