![]() | Home > Td5 > TD5 EGR Solenoids |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Do you disconnect the wiring to the vacuum solenoid when you blank the EGR off? Does the ECU know and will it run differently when its disconnected?
Its a 2003 EU3 model by the way. |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
No wires
The wires are to the vacuum solenoids which controls the supply of the vacuum to the actual EGR valve on the inlet manifold.
Sure ive read somewhere to disconnect the wires after removing the EGR, just not sure! lol |
Just replace the egr with a egr kit pipe and blank or join the vacuum pipes at the egr end
Thats the plan but to remove the pipes that arent needed.
Was just told that then ECU will fuel the engine different if the wires are disconnected, just trying to find out if thats true or not and if its for the better or not? |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 265 ![]() ![]() ![]() |
Guys
why not drop an email to Bell Auto Services, there seem on the ball with these things, and very helpfull too. Cheers keith puer claudius |
Do they do a kit as well because i want to remove the valve completely.
Thanks
