Home > Td5 > TD5 EGR Solenoids
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
TD5 EGR Solenoids
Do you disconnect the wiring to the vacuum solenoid when you blank the EGR off? Does the ECU know and will it run differently when its disconnected?
Its a 2003 EU3 model by the way.
Post #10858 13th May 2009 7:13pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
No wires Shocked it should be vacuum pipes, just join them together Thumbs Up
Post #10859 13th May 2009 7:31pm
Zinke
The wires are to the vacuum solenoids which controls the supply of the vacuum to the actual EGR valve on the inlet manifold.
Sure ive read somewhere to disconnect the wires after removing the EGR, just not sure! lol
Post #10860 13th May 2009 8:49pm
Sonic3d
Just replace the egr with a egr kit pipe and blank or join the vacuum pipes at the egr end Thumbs Up
Post #10861 13th May 2009 8:57pm
Zinke
Thats the plan but to remove the pipes that arent needed.
Was just told that then ECU will fuel the engine different if the wires are disconnected, just trying to find out if thats true or not and if its for the better or not?
Post #10863 13th May 2009 9:34pm
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
Guys
why not drop an email to Bell Auto Services, there seem on the ball with these things, and very helpfull too. Cheers
keith
puer claudius
Post #10873 14th May 2009 7:33am
Zinke
Do they do a kit as well because i want to remove the valve completely.
Post #10930 15th May 2009 8:38pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Re: TD5 EGR Solenoids
The electrical connections to the EGR solenoids can be disconnected and the solenoids removed completely. The ECU doesn't seem to fuel it differently and mine has been running just fine. I can recommend the IRB Developments/Bell Autos EGR removal kit - they provide a proper replacement vacuum pipe rather than just bunging up the existing pipes. The brake servo depends upon that so it's best not to bodge the job. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #10940 16th May 2009 8:26am
Zinke
Thanks
Post #10947 16th May 2009 2:54pm
