Home > Technical > PUMA rear diffs?
Page 2 of 4 <1234>
jst
well 4 days later, they have rung to say they have stripped the diff and taken some pictures(!) and LR technical have kindly let me have authority for another diff, its just a shame there arent any around it would seem.
They didnt know if the one that came out was 2 or 4 pin - well the bloke on the phone didn't know anyway! and he didnt know if a 2 or 4 pin was going back in instead. i have tried the same route as Andrew ref the 4 pin so we will see. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #10768 12th May 2009 2:56pm
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Right, right, I know, thanks a lot.
I didn't know that LR have this option for 2 or 4 pins.
Good to know.
regards
Post #10770 12th May 2009 5:18pm
ashtrans
Site Sponsor
Hi,
just to clear this up,
all Puma front diffs are TBB000250 which is a 2 pin diff, this can be upgraded to the stronger 4 pin diff TBB000280,
as above for the 90 rears,
the 110 rears are all 4 pin and are TBB000270, this is the shorter housing design like the P38 diffs, not interchangable with the front 'normal' longer housing,
The noise issues could either be poor manufacture of the ring and pinion or incorrect assembly, Dave
Post #10779 12th May 2009 8:17pm
MK
I heard LR had t some point some issues with the manufacturing of crowns and pinions. Is it true? Puma 110" SW
Post #10780 12th May 2009 8:28pm
jst
Cheers for the update Dave, very much appreciated. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #10781 12th May 2009 9:00pm
AndrewS
ashtrans wrote:
Hi,
Thanks Thumbs Up
Post #10782 12th May 2009 9:52pm
mse
Anyway to get the 4 pin under warranty without it going bang Whistle Thumbs Up Mike
Post #10786 12th May 2009 10:50pm
MK
The difference seems to be around 300 quid! Puma 110" SW
Post #10788 12th May 2009 11:40pm
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Thanks Andrew and Ashtrans we are all alot wiser, maybe you could inform LR and tell them where they are going wrong, ashtrans
Post #10840 13th May 2009 2:41pm
ashtrans
Site Sponsor
Hi,
a while back we bought a batch of new boxed landrover diffs, the type we got were the 3 bolt flange version but as we sell more of the 4 bolt flange type we swap this flange and convert them.
We were doing a batch of these this morning and due to this noise thread I though we would just check one of these new ones.
As a part of the rebuild process we 'blue' the gear teeth to check the contact patch and adjust the pinion height as required to get this contact patch correct to make sure the gears will be quiet.
here is what we found :
I am not sure if you can see it but this is bad, very bad,
I cannot be sure if this is due to incorrect manufacture or incorrect pinion height, to answer this we need to chnage the pinion height to see if we can get a good contact patch, if not we would assume poor manufacture and scrap the ring and pinion, either way we would not send this out the door as it would almost definatly be noisy.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Dave
Post #10920 15th May 2009 11:39am
Grockle
Engineers blue not seen that since my apprentice days 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #10921 15th May 2009 11:42am
MK
ashtrans wrote:
Hi,
Dave:
Any difference on the crown and pinion with the ones on the latest 110"-130" pre-Puma?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Puma 110" SW
Post #10923 15th May 2009 12:41pm
ashtrans
Site Sponsor
Hi,
this is on a 'rover' type diff, ie 90, front and rear and 110 front,
I don't have any new 110 rear diffs to check but I wouldn't be surprized if we saw a similar thing, Dave
Post #10927 15th May 2009 1:04pm
mhasting2004
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Hi ashtrans
Could you explain to us that aren't experts in diffs what it is that is really bad in the contact pattern shown? I'm only a 10 minute google search expert and from that it looks that the contact is a bit high on the tooth but well centered. Or is it that it seems to be such a small contact area?
I'm about to get a new rear diff put in this week and I am wondering is it common practice to blue up a gear prior to instalation to check it, or do most dealers Ass-U-Me they are right from factory?
Mark
Post #11009 18th May 2009 2:14am
MK
AndrewS wrote:
markalpha I was lead to believe that they are 2 pin. The reason behind this was that's what I was told by LRCC. When I asked for the diffs to be up graded to 4 pins (I offered to pay the Extra) I was told NO by LR as it would invalidate my warranty as the vehicle is not standard Shocked Shocked Shocked I know I could not believe it either. However Ashcroft Transmissions has posted on this forum saying that the diffs are all 4 Pin.
Gabriel Boff
Check out this link you will see an animated image showing a working 2 pin Diff. The red objects in the animation are what's called the 'pins'. If you were to add 2 more 'pins' between the existing ones you will then have a stronger 4 pin diff.
http://auto.howstuffworks.com/differential2.htm
all 110" are 4-pin (rear) Puma 110" SW
Post #11070 18th May 2009 10:57pm
Page 2 of 4 <1234>
