![]() | Home > Technical > PUMA rear diffs? |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
I`ve had 2 rear diffs so far due to what sounds like a high spot on the pinion gear, you only noticed it at slow speeds. Mine has a 4 pin diff and its an 08 double cab
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Yes had a new Rear Diff 10 months ago in our 110 Utility 57 plate not sure if 2 or 4 pin, been ok so far. It went in a quarry and as soon as we got speed up on the road it was very loud and rumbling/grinding. Dealer got it sorted under warranty.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8205 ![]() ![]() ![]() |
cheers guys so a known fault it would seem. thats good to hear. Cheers
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
You recon ![]() ![]() Main Brian James Trailer Dealer for South West UK |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Well I am on number 5 on the rear and 3 or 4 on the front.
Are you still using LR diffs Andrew
Yep so far the latest ones have held up ![]() ![]() ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Other than rubbish design
Is there any reason for failures? Mike |
increased torque and lower gearing? we had alot go on steep descents but they were all front diffs which with a fully loaded 110 and low 1st thats a lot of engine braking on a component. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Are they 2 or 4 pin Andrew, good to hear you are having something go right for you.
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 ![]() ![]() ![]() |
Hi (remember i'm from Brazil)
- What is "pin", and "2pin" , "4pin"???? - How you can broke that much of LR diffs????? Here in Brazil the jeep and toyota diffs are common, but the war CJ's and FJ40, not the modern ones, and all the LR diffs are much, much, much, much more strongest!! i'm impressed how tuff it is knowing my 09 90 CSW, I ask: How you broke it? Is it in off road? Or excessive speed/distance? regards |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2463 ![]() ![]() ![]() |
2-4 etc pins are the "satelites" small conical pinions playing inside the carrier. Probably LR did not test them app with the new high torque engine. Puma 110" SW
Yeah yeah now I understood!!!
Thanks! Some notice of this problem occuring with 90's???? att |
markalpha I was lead to believe that they are 2 pin. The reason behind this was that's what I was told by LRCC. When I asked for the diffs to be up graded to 4 pins (I offered to pay the Extra) I was told NO by LR as it would invalidate my warranty as the vehicle is not standard
![]() ![]() ![]() Gabriel Boff Check out this link you will see an animated image showing a working 2 pin Diff. The red objects in the animation are what's called the 'pins'. If you were to add 2 more 'pins' between the existing ones you will then have a stronger 4 pin diff. http://auto.howstuffworks.com/differential2.htm |
