Home > Puma (Tdci) > Fuel issues on a 2014 2.2
CornishLandys101
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Fuji White
Hello I had great disappointment today after picking my Landy up from a passed MOT only to idle really rough engin light came on and it stalled repeatedly!! I checked the codes and I have P0088 and P117E I have seen these are
(fuel voulume regulator control exceeded minimum control limit)
Fuel rail/system pressure too high)
Can anyone help what this may be? It seems to contradict itself to me but what do I know I’m just the idiot who owns it.
Thanks for any help
Post #1061625 28th Feb 2025 9:35pm
landy andy
Change the VCV they like to fail.
Post #1061628 28th Feb 2025 9:49pm
I do agree with Andy above, I think that is likely, it doesn’t produce a DTC itself, but will mess with the fuel pump pressures, which then in turn that does create a DTC.
VCV’s aren’t very expensive which is probably some good news, and easy enough to change yourself carefully. Thumbs Up TheThunderRolls🇬🇧🇺🇸
Post #1061631 28th Feb 2025 10:01pm
Dinnu
Not common on 2.2. If it was a 2.4 yes. But without better options guess worth a try. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1061641 1st Mar 2025 2:58am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: Fuel issues on a 2014 2.2
Fuel pump or rail pressure sensor
Post #1062013 4th Mar 2025 9:15pm
Ianh
When was the fuel filter last drained or changed ?
Post #1062015 4th Mar 2025 9:51pm
CornishLandys101
Apologies for a delayed reply, it has just had a service with fuel filter changed, I’ve been researching the VCV valve and that could be it I’m reading some slightly different symptoms, mine is fine until I’ve taken it for a good drive then if I try to restart it it goes into limp mode with those error codes it wouldn’t even start the other day after a 2hr drive where it was fine.
Dose anyone know if I change th fuel Controll valve will it need programming I’m reading mixed things?
Post #1064556 3rd Apr 2025 9:10am
No programming needed, I got mine from PF Jones.
It does very much likely sound like it is the VCV.
It’s easy enough to do and plenty of guides on here, must be kept very clean, and a 2 step tightening process, which is not as complex as it sounds.
In effect, just don't over tighten the two fixings.
VCV issues, tend to be worst when cold can result in stalling and engine cut outs, and also lacking power in high gears especially 6th.
When cold idle not as smooth as expected either, it would pay to clean your MAF & MAP Sensors, plus a drop of light oil on the Turbo ‘Actuator pivots as well, that just helps keep things smooth.
You should be able to find the torque settings on here, if not drop me a ‘PM’ and I might be able to find them for you. TheThunderRolls🇬🇧🇺🇸
Post #1064562 3rd Apr 2025 10:23am
Ianh
As Dinnu pointed out, A VCV failure on a 2.4 is unfortunately a common issue , however it’s very rare for a VCV to fail on a 2.2. In fact I’ve not seen a topic where its confirmed a failed 2.2 VCV is the issue.
On a 2.4 it’s recommended that once a VCV is changed a pump learn and pilot correction is undertaken. However from many reports this is unnecessary as a new VCV is learnt over a few driven miles.
As for a 2.2 I’m not sure, a couple of people have changed them, only to find the VCV was not at fault. In these cases I believe they did not need to undertake a learn of the new VCV via diagnostics equipment.
Having said all of the above I suspect the issue is air getting into your fuel system. Very likely due to the new fuel filter not seating correctly. This can be because it has not been correctly screwed in or in the case of some non genuine filters poor design. I would prove it’s not filter related as your first course of action.
Post #1064565 3rd Apr 2025 10:54am
Ianh
Custom90. The 2.2 VCV removal and replacement procedure is very different from the 2.4
A how too was provided by member Timcat https://www.defender2.net/forum/topic86260.html?highlight=vcv
Noting , that it transpired the VCV was not at fault for Timcats issue , It turned out to be a crack in the inlet manifold blowing oil residue up under the LP drain off! Which like yours generated a P117E-22 DTC
Timcat may be able to provide more info if needed, however he has upgraded his Defender to a UNiMog so may not be on the forum as much.
Post #1064566 3rd Apr 2025 11:18am
andy63
My thoughts are before you replace anything try and confirm a few things..
If its a non start issue when hot can you say what the rail pressure is when cranking.. it's common strategy on common rail not to a activate injectors until it sees a given pressure..ie close to 200 bar..
If reduced pressure then check the lp side from the tank pump..you would expect it to eventually start if that is running, even with an air leak on the filter..bleed it at the vent valve
If all that checks then I'd turn my attention to the vcv..
I keep meaning to try a start with that disconnected but never got round to it yet.. it's a pain to get at the connector..
Post #1064571 3rd Apr 2025 11:50am
Ianh
Easy to bleed the 2.2 as it has a pump in the tank. Just turn ignition to position II ( don’t crank engine) leave for 10 seconds, you can hear the fuel pump running. Turn key fully back and then repeat a couple of times.
Engine should then start .
Ps was the vehicle ok before the fuel filter was replaced. just want to discount the fuel filter.
Post #1064574 3rd Apr 2025 11:57am
Julie
In the www you find some 2.2 displaying the P0088 due to a faulty pump which is costly and hard to find
Therefore check if the fuel line from the rail back to the tank ils blocked for some reason. IMO bleeding is not possible. It's more a visual inspection.
Look for the pressure sensor, too.
Could also be related to voltage at the fuel pump, but difficult to imagine why voltage rises only at the fuel pump
Post #1064697 4th Apr 2025 9:14pm
andy63
We are talking about a 2.2 l puma here..so there is no fuel return or leak off from the common rail back to the tank as far as i can remember..the leak off pipes are from injectors and pump itself..
It does have a pressure sensor on the back end of the rail..
The electrical connection to the pump is the vcv valve supply..I think that has to have a supply in order for the vehicle to start, and I did mean to check that out, but not done it yet..
It operates on a pwm/duty cycle signal
The other electrical connection at the pump is the fuel temp sender..
So back to what i suggested..check the rail pressure at cranking in the no start condition..and as discussed above go from there..👍
Post #1064727 5th Apr 2025 9:14am
andy63
Another point that comes to mind that can short circut the diagnostic process of checking the fuel supply system, is simply check the operation of the injectors if you can.. if they are been operated then you can be fairly certain all else in the fuel system including the rail pressure is 👍..
Just be careful as the operating voltages are high.. again from memory I'm thinking 120/140V.. current in range of 7 or 8 amps max i 🤔
Post #1064732 5th Apr 2025 10:00am
