![]() | Home > Puma (Tdci) > Another output shaft..... |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1463 ![]() ![]() ![]() |
Popular opinion among those that have looked into the problem, is that there is an alignment issue between the gearbox and transfer box on the vehicles that have a short shaft life.
If this is the case, fitting a one piece shaft will cause wear in another area. Either the gearbox output or the transfer box input, rather than the connection between the original 2 piece shaft and socket. How long it takes for problems to arise in the other areas remains to be seen. The only certainty is if you've had the problem once, and do nothing to fix it, it will happen again. Good luck with whatever option you go for! ![]() |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2668 ![]() ![]() ![]() |
Thanks Dinnu & DSC, that clears it up for me.
The misalignment would also explain why many Pumas never suffer from this issue, while others do - LR's typical 'build quality' ![]() Well, seeing that the LOF one is out of stock, I will end up buying the Ashcroft kit as my Puma is going into the shop next week for some transfer case TLC. ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
I need to stop, else the Mrs will be very cross with the bank balance
![]() ![]() Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 571 ![]() ![]() ![]() |
Corrosion alone would also explain it , since we all know that some cars having corrosion issues don’t pass the MOT while others never suffer from these problems. |
Ashcroft kit arrived this am, Orxy will be going into the shop on Wednesday
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 170 ![]() ![]() |
To all the Ashcroft upgraded shaft guys, how does it look 4 to 6 years after? Making my Defender great again. (Or trying to at least xD)
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2231 ![]() ![]() |
How’s your LOF one piece shaft performing ?
At 70k miles I’ve decided to drop the transfer box and have a good look at the adapter shaft. if it’s worn I will replace and so it will be Ashcroft, LOF or IRB decision time. Genuine shaft and cup with grease or genuine shaft and cup with a grease nipple in the cup and drilled adapter housing I’ve discounted. I’m aware of all the pros and cons of all the options, just wanted some up to date feedback on those that have fitted the one piece LOF solution, in particular how many miles they have achieved and any issues with the MT82 and / or LT230 box’s. |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 916 ![]() ![]() ![]() |
I’ve got the LOF unit in our 2.2 Puma. It hasn’t covered that many miles since the conversion, but so far there have been no issues with anything in the transmission. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 916 ![]() ![]() ![]() |
I’m around a year in since doing the single piece LOF and not one complaint so far. 2008 2.4 110 Utility Station Wagon XS.
