Home > Puma (Tdci) > New technical bulletin regarding brake vacum pump (LTB00177
Page 2 of 3 <123>
Eduardo
Yorkshireland
Is the first type one, the same that I have (change one time before the 1st bulletin).
Cheers! Eduardo
Post #10634 10th May 2009 5:38pm
YORKSHIRELAD
Eduardo wrote:
Yorkshireland
Cheers!
Thanks Eduardo my friend!. I thought as much as it's only just done 3000 miles.Now I know where it is at least I can check it for oil leaks. I wonder how much Land Rover would charge for the latest one just as a part, not fitted?.
Thanks,
Richard 1963 Series 2A truck cab
2008 110 SW
Post #10636 10th May 2009 5:53pm
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
YORKSHIRELAD wrote:
Eduardo wrote:
Yorkshireland
Cheers!
Thanks,
Richard
Here there were no Landrover parts so the specialtly shop used a Ford one and Landrover accepted it
Post #10641 10th May 2009 8:19pm
YORKSHIRELAD
[/quote]Here there were no Landrover parts so the specialtly shop used a Ford one and Landrover accepted it[/quote]
Hi Sasha2001. Is this the case for all of the attempts to get it right then?. In the case of the latest bulletin with the new gaseket as Eduardo kindly told us about in the first post, could we buy one from Ford?. I would rarther buy one and have it fitted than wait for the inevitable to happen.
2008 110 SW
Post #10645 10th May 2009 10:24pm
bustduster
Heard yesterday that there is a fourth vacuum pump replacement available. Not sure if this is the same as GTR bulletin in April 2009, as I was under the impression that that was a second replacement. Can anyone confirm that the bulletin of April 2009 is still the latest vacuum pump replacement?
Post #11742 9th Jun 2009 9:13am
NoDo$h
Must be doing something wrong - our 07 is still on the original pump.
Place your bets folks, place your bets. Failure by the end of the month is now guaranteed......
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #11744 9th Jun 2009 10:31am
RgrBox
United States 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
Mine looks OK.. but the gasket at the front of my engine next to this pump shows some oil around it.. Should I have this looked at? 2008 110 2.4 tdci csw
Landrovers of Switzerland Club member
Post #11752 9th Jun 2009 12:00pm
Grockle
Yes,better safe than sorry. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #11756 9th Jun 2009 1:20pm
RgrBox
Thanks.. I guess I'll have to bring it by the dealer...
RB 2008 110 2.4 tdci csw
Post #11759 9th Jun 2009 2:46pm
Eduardo
Regarding this question:
Last bulletin regarding the vacuum pump has beem issued in May 22 2009, were they update the change procedure of the pump
SSM41258
Models: LD - Defender
Title: Defender 07 My on Vacuum Pump replacement procedure change
Last Modified: 22-MAY-2009 08:55
Category: Chassis
Symptom 301000 Service Brake System
Content
Issue: Changes to service process Defender 2007my
Methods engineers at Land Rover have recently studied the service process for renewal of the brake vacuum pump for Defender (LD) 2007MY onwards models (2.4 Puma).
In the new procedure the coolant fan is no longer removed and the battery is not disconnected.
Should it become necessary to renew the brake vacuum pump on Defender (LD) 2007MY onwards models (2.4 Puma), refer to the updated procedure on GTR section 206-07: Power Brake Actuation.
Old Repair Time: 70.50.19 – Vacuum pump – brake booster – renew – 0.70hrs
New Repair Time: 70.50.19 – Vacuum pump – brake booster – renew – 0.40hrs
Last issue regarding the pump itself has been issued on April 21, 2009
Technical Service Bulletin No.LTB00177v3 - 21 April 2009
Reissue: Please replace the previous edition of this bulletin.
This bulletin supersedes TSB LTB00177v2/2008 dated 27 October, which should either be destroyed or clearly marked to show it is no longer valid (e.g. with a line across the page).
Subject/Concern: Brake Vacuum Pump Seal Oil Leak
Models: Defender (LD) 2.4L Diesel 2.4L Diesel VIN-range: 7A732615-9A779263
Markets: All
Section: 206-07
Summary: Oil leaking from the brake vacuum pump front oil seal. This version has been issued for a change in the Causal Part and End VIN.
Cause: Dirt ingress into the pump pulley seal resulting in damage to the lip and subsequent oil leakage (the new brake vacuum pump has a secondary dirt lip seal). Suggested Customer Concern Code - R31.
Action: Should a customer express concern, install a new brake vacuum pump (refer to Global Technical Reference GTR Workshop Manual, section 206-07).
Parts Required:
Description Part Number Quantity
Brake vacuum pump LR014973 1
Gasket LR004381 1
Labour Time:
Operation Description Operation No. Time
Install a new brake vacuum pump 70.50.19 0.7 hours
Repair/Claim Coding:
Causal Part: LR006782
ACES Condition Code: 42
Defect Code:
Cheers Eduardo
Post #11760 9th Jun 2009 4:05pm
bustduster
Cheers Eduardo, that clears up the confusion. Looks like a procedural matter rather than a new version. I was a bit concerned as my April 08 110XS went in yesterday for the clutch to be relaced with the updated version and they said they would replace the vacuum pump as I would rather have it sorted before it was likely to fail.
Post #11762 9th Jun 2009 4:39pm
Eduardo
Your welcome, in fact the last one is a procedure change
I have in conversations with our dealer for at least 1 year to change the old model pump (still not leaking) without success. Sad
Cheers Eduardo
Post #11763 9th Jun 2009 4:43pm
bustduster
The Technical Service Bulletin says it all! "Should a customer express concern, install a new brake vacuum pump". I expressed my concern to the dealer that many pumps had already failed and I would not be too happy having mine fail on a trip as the mileage builds up, especially as it is a known issue and they are now on their second upgrade. Perhaps you could try again and hope that your dealer is a little more cooperative!
Post #11767 9th Jun 2009 8:12pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Just had a bunch of stuff done on mine including the vacuum pump (a load of oil sprayed all over the underside of the RHS of the bonnet gave it away). The quantity of oil is not that high so I doubt it would cause problems on most trips. Still worth either getting it looked at or carrying a spare if you're out for an extended period. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #11824 10th Jun 2009 9:50pm
MK
add a few oil drops behind the pulley and drive through a dusty road. Puma 110" SW
Post #11825 10th Jun 2009 10:03pm
Page 2 of 3 <123>
