Home > Puma (Tdci) > Key stuck in ignition
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Hi all
Had a call from a friend with a 2013 Defender crew cab. The key is stuck in the ignition barrel and after lubricating with Plus Gas it still refuses to come out.
Any ideas?
Jim
Post #1062273 7th Mar 2025 11:14am
revd
I replaced the barrel on my Td5 when the same thing happened- there is an internal roll pin which had shifted slightly- probably fixable but was off to France and didn’t want to risk being stuck somewhere
Post #1062276 7th Mar 2025 12:19pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Yes happened to me. With a lot of wiggling, turning the key and steering wheel it eventually released. I have since replaced the barrel as I didn’t want that happening again.
Post #1062282 7th Mar 2025 1:11pm
Depending on situation hot glue might be useful to tease out the existing remains of the key.
Depends on the situation of course, and such tools aren’t often to hand in that situation. TheThunderRolls🇬🇧🇺🇸
Post #1062307 7th Mar 2025 7:10pm
revd
Lock assembly is fixed to the column with shear bolts. Puma access is poor so not an easy roadside repair, Td5 has reasonable access to drill the bolt heads that secure the lock
Post #1062312 7th Mar 2025 7:48pm
TexasRover
You can rotate the shear bolts with a hammer and sharp punch. Anyway I replaced mine with normal bolts when I changed my barrel. Bought the set with door locks and 4 keys, original land rover not that expensive I recall.
Post #1062322 7th Mar 2025 8:55pm
Ianh
If you disconnect the starter battery you can then turn the key completely clockwise until it hits the stop, then apply a little more pressure and give it a little wiggle. Then fully anti-clockwise . Do this a few times while wiggling key and steering wheel. This may release the key.
Post #1062325 7th Mar 2025 9:17pm
