![]() | Home > Puma (Tdci) > Key stuck in ignition |
revd Member Since: 20 Apr 2024 Location: England Posts: 220 ![]() ![]() |
I replaced the barrel on my Td5 when the same thing happened- there is an internal roll pin which had shifted slightly- probably fixable but was off to France and didn’t want to risk being stuck somewhere
John P Member Since: 26 Dec 2013 Location: West Sussex Posts: 342 ![]() ![]() ![]() |
Yes happened to me. With a lot of wiggling, turning the key and steering wheel it eventually released. I have since replaced the barrel as I didn’t want that happening again.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
Depending on situation hot glue might be useful to tease out the existing remains of the key.
Depends on the situation of course, and such tools aren’t often to hand in that situation. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Lock assembly is fixed to the column with shear bolts. Puma access is poor so not an easy roadside repair, Td5 has reasonable access to drill the bolt heads that secure the lock
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1224 ![]() ![]() ![]() |
You can rotate the shear bolts with a hammer and sharp punch. Anyway I replaced mine with normal bolts when I changed my barrel. Bought the set with door locks and 4 keys, original land rover not that expensive I recall.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2240 ![]() ![]() |
If you disconnect the starter battery you can then turn the key completely clockwise until it hits the stop, then apply a little more pressure and give it a little wiggle. Then fully anti-clockwise . Do this a few times while wiggling key and steering wheel. This may release the key.
